CV Joints - Defender Source
Old June 7th, 2010, 09:37 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
CV Joints
In the middle of complete resto and currently working on the front axle. I have the CV joints torn down and am not sure what I'm looking for in terms of wear? There are a few stains on the polished surfaces but nothing I can feel with a finger nail. The truck has 100k on it and I'm pretty sure they are original. What should I be looking for?
I hate to spend money to replace them if they're still good.
There were some "noises" from the front end before the resto, but I had attributed that to the power steering box which is shot.
ID:	28322   Click image for larger version
Old June 7th, 2010, 10:03 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Answer depends on if you are going to wheel it or is mainly a road vehicle. Show piece, put them back in. Wheeler, Rovertracks CV's.
Old June 7th, 2010, 10:29 AM
That is one school of thought, just throw a bunch of money at something without learning anything. Others might say, if you are running 33" tires or less keep running the stock stuff. Drive sympathetically and you should have minimal problems. If you break something, secondhand spares are cheap and easy to install. That said, the RT stuff is relatively inexpensive, especially if you factor in the potential costs and time for repairs of broken factory items, and pretty much eliminate the potential for shaft/CV breakage as I understand it. Mind you, if you swap the axles and CVs you still have to do something about the weak ring and pinion so if you have a heavy right foot you will probably just break something more expensive and difficult to change. Anyway, just wanted to point out that there are options and there are people running stock setups out there.
Of course now that I said that I will probably break something
I would say put those CV's back together and see if there is any free rotational movement in the joint. If so you might want to replace, there are probably specs published somewhere but generally I don't think you would want any perceptible wear in them.
Old June 7th, 2010, 10:42 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
"Of course now that I said that I will probably break something" I'll be here
Those CV's look fine and Like Kevin say's if your biggest planned obstacle is a parking block at the mall you'll be fine
Really the CV's don't need to get bigger and badder unless you install a front Locker or wheel in high traction locations. I have seen guys with unlocked front break CV's I've also seen guys wit lcokers run stock CV's for ages and not break them.
The 3.54 gears aren't all that weak but the single cross pin diff is. Generally if they get to a ripe old age (I won't apply milage here because it depends on the type of use the diff gets) the cross pin will fail and make a big mess.
Keith
Big, Red and ... aaa Red..
hardened or 1 ton CV joints cdb Defender Technical Discussions 4 January 24th, 2009 07:17 PM
Anybody ever redone the steering joints? Hans Defender Technical Discussions 2 January 19th, 2006 12:43 AM
Anti Roll Bar Joints TDI Guy For Sale - Parts 3 December 17th, 2004 08:05 PM
stronger CV joints Ced Defender Technical Discussions 7 July 6th, 2004 11:48 AM
CV Joints flippedrover Defender Technical Discussions 16 May 20th, 2004 07:09 AM
