CV joint gone bad? - Defender Source
Old December 4th, 2005, 02:17 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
CV joint gone bad?
I seriously am starting to think it's time to redo the CV joint on one side, but won't know till I tear it apart to see. If the wife's car gets back from the shop Monday like expected, I'll tear it down ASAP. But I figured I'd get some input first before I start stripping things down. My guess right now is the cage is probably shattered.
Symptoms:
1. Serious endplay, When I have the drive flange off, I can push the shaft in about 1/2"
2. Leaking fluid between the driveshaft and spindle.
3. I think that the noises I'm hearing are coming from that area. Really bad clunking, and now a kind of grinding noise occasionally.
Also, if you get a CV joint kit, what the heck does that include? Is it the whole assembly including the cage, star, balls and the short outer shaft?
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 4th, 2005, 07:43 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Does the noise get worse on full steering lock?
Mike Hammond
Old December 4th, 2005, 11:03 AM
Symptoms:
-Hans
1) That is the way they are designed. The circlip on the flange is the locator to prevent movement inwards, the CV bush to prevent movement outwards. With the flange off it can move around 1/2". With the drive flange on and the circlip in place there should be a set end float (0.007" IIRC) which is set by shims behind the circlip.
2) Normal. That seal typically does not work.
3) A CV will clunk at full lock with the wheel speed. Have you tried driving with the front driveshaft off?
Can't hurt to pull it apart anyway.
Old December 4th, 2005, 01:42 PM
Hans's Avatar
Hans
Hans Haase
The clunking is totally independant of wheel posiition from what I've seen. The other noise, not sure how to describe it, but that one is also typically only with the wheels straight and is speed dependant..... regardless of gear or RPM.
Now you've got me wondering, since the other side has much less endplay with the flange off. Definitely something different between them causing that. It's not stopping me from driving for now, but I think I'll be pulling it apart once this snow melts. Best case is nothing is wrong and I have an excuse to clean and change the swivel fluid.
-Hans
My oil line fix
Old December 4th, 2005, 03:03 PM
mikeslandrover
Mike Hammond
My discovery had a strange clunking from the front end, had me baffled for a day or two, two clunks per wheel revolution, turned out to be the road wheel starting to fall off
The wheel nuts were just a tiny bit lose and the ally wheel was moving around on the flange.
Never rule out the obvious!!!!! (even if i wasn't obvious at the time!)
Mike Hammond
Old December 4th, 2005, 04:24 PM
Hans's Avatar
Hans
Hans Haase
No sense it being macho, I'll check the lugnuts too. Doubt it, but you never know until you look.
Though I did listen real careful today, and I could swear I heard the crunching/popping that is typical of CV joints in other cars. I'm just so used to the exposed U-joint style knuckles that most other solid axle 4wd's use, never really worked on a CV joint before.
-Hans
My oil line fix
CV Joint Removal Lriwater Defender Technical Discussions 21 September 7th, 2009 01:36 AM
Symptoms of a bad axle CV joint? Hans Defender Technical Discussions 16 April 6th, 2007 01:20 PM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
Need a 110 HD CV Joint tonight if possible chrisvonc Defender Technical Discussions 1 May 28th, 2004 11:46 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
