CV joint failure? - Page 2 - Defender Source
Old February 25th, 2016, 04:36 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I don't think I have clarified previously, but the front axle is from a 1995 D90. So it doesn't have that bushing.
Old February 25th, 2016, 05:07 PM
The later axles have a needle bearing instead, item 21. Did you check on that?
Old February 25th, 2016, 05:20 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Yes, I did inspect it. I had a new one to put in but the old one did not appear to have any more play in it than the new one. Plus I didn't have a good way to remove the old one since it is hard to access from the back side to knock it out. It doesn't seem like there would be enough play there to create the noise I hear, but I'm sure it's possible.
Old February 25th, 2016, 10:03 PM
I'm out of ideas. Is your caster much more positive than usual due to cranked radius arms? Maybe an alignment / toe issue causing slop in the diff to take up due to scrub? Loose panhard? Bad ball joints? Trying to figure out what would cause a low frequency intermittent sound.
Old March 20th, 2016, 06:32 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Might be a stupid question but should the CV joint be able to bend far enough to hit the inner shaft?
Old March 20th, 2016, 06:39 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yeah, that's normal.
Of course when its inside a swivel housing the range of motion is limited.
Rent my
Old March 20th, 2016, 07:14 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I replaced the other side but the knocking noise remains. Trying to decide if I should replace this one too. The wheel bearing on this side had a lot of play, so replaced that. Will probably just do the cv since I have it all apart.
Old March 20th, 2016, 07:22 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Do you mean the whole hub was loose?
Rent my
Old March 20th, 2016, 07:27 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I mean when I jacked the wheel up and grabbed the top of the tire I could move it because of play in the bearing. The hub nut was not loose.
Old March 20th, 2016, 07:33 PM
Make sure you are checking the swivel bearing and setting the swivel preload while you are there.
Old March 20th, 2016, 08:38 PM
Yeah...the symptom you describe (wheel bearing nut tight but wheel has play) is classic swivel ball tension issue.
Old March 20th, 2016, 09:31 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Would the swivel preload cause a knocking noise?
Old March 20th, 2016, 09:41 PM
No idea but it aint right so fix it
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
a-arm joint/ wishbone joint cbass Defender Technical Discussions 4 January 21st, 2007 09:35 PM
Rear trailing arm bushing failure sheki Defender Technical Discussions 23 July 5th, 2006 09:20 PM
Tailight failure rustydefender Defender Technical Discussions 9 August 15th, 2005 01:23 PM
