Cv joint differences - Defender Source
Old October 20th, 2013, 11:13 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I have a 96 disco front axle in my 84 110. One of the front cvs is failing and needs to be replaced. Aside from the abs wheel are there any other differences between the two cv styles?
Ryan
Ryan
84 110SW County LHD
07 L322 Vogue
Old October 20th, 2013, 11:16 PM
Yes. The 84 110 has the AEUxxxx CV which is longer for the thick drive flange and has the 23 spline inners. They are not interchangeable.
Old October 20th, 2013, 11:29 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I actually meant the later style defender with the 33 spline inners and non abs.
Ryan
84 110SW County LHD
07 L322 Vogue
Old October 20th, 2013, 11:41 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I guess i was just cross eyed looking at parts seems that all 33 inner spline cvs have abs..
Ryan
84 110SW County LHD
07 L322 Vogue
Old October 21st, 2013, 12:02 AM
Not sure on that. I thought 94/95 d90s did not. Certainly suffix b RRC do not and they are 33 inner.
Old October 23rd, 2013, 03:47 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
32 spline inner, not 33.
The ABS ones have the excitor (sp?) ring on the outside, but these will fit into a non ABS stub, had one in an older 90 I used to own.
Apart from the old classic rangie with the 10 spline CV that didn't have the stubs on it (stub was connected to the drive flange) then all the 32 splined ones are interchangeable.
New Geniune CV U Joint 1987 1988 1989 1991 1992 RTC5843 azarmadillo For Sale - Parts 1 March 1st, 2013 04:40 PM
CV Joint Removal Lriwater Defender Technical Discussions 21 September 7th, 2009 01:36 AM
Symptoms of a bad axle CV joint? Hans Defender Technical Discussions 16 April 6th, 2007 01:20 PM
CV joint gone bad? Hans Defender Technical Discussions 5 December 4th, 2005 04:24 PM
Need a 110 HD CV Joint tonight if possible chrisvonc Defender Technical Discussions 1 May 28th, 2004 11:46 PM
