cuuting the hole in the wing for a snorkel - Defender Source
Old July 27th, 2007, 06:15 PM
cdb
Clark Bowen
I went with the Southdown snorkel and I can make it work on the passenger side by weaving the hose from the snorkel under the heater and over to the air cleaner.
However, a body shop and then Shane mentioned that since I would be cutting through the seam where the outside and top wing pieces are joined it will weaken the wing and the aluminum could fatigue and crack.
Has anyone cut through this area (right in front of where the rollcage bolts through the wing) and then seriously offfroaded it? Did anything crack?
Clark
Old July 27th, 2007, 08:42 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Clark
It won't. Your fine.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 27th, 2007, 11:55 PM
cdb
Clark Bowen
Thanks Buck.
Old July 28th, 2007, 11:32 AM
cdb
Clark Bowen
Jeff............
How would you form a lip?
Clark
Old July 28th, 2007, 01:35 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Have the same snorkel and cut the same hole. No problems.
Old July 28th, 2007, 03:12 PM
cdb
Clark Bowen
thanks Keith
Old July 29th, 2007, 08:12 PM
cdb
Clark Bowen
Thanks Jeff, - although I hope it doesn't wind up looking like your Avatar.
Clark
Old July 29th, 2007, 08:19 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Dido. I've had the same snorkel for 5 years and no issues.
Old July 31st, 2007, 06:05 PM
cdb
Clark Bowen
Jeff posted
"Im hurt. Ill have you know that a couple years ago I won third place at the PDX ABFM with that fine gem"
What category?
Seriously though, how did you cut the hole for your snorkel without the hole saw wobbling and making a mess? I cut a better hole in my index finger with the d%$# thing last night and had to go to the ER and I just started my pilot hole.
Clark
Old July 31st, 2007, 09:43 PM
cdb
Clark Bowen
Thanks Jeff.
No pictures of the mess of my index finger. I don't even like to look at it.
Clark
Old July 31st, 2007, 09:58 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Using a hole saw on an uneven surface, as you found out, is a very dangerous thing to do. It will want to grab, and do all kinds of nasty things. I try not to use them with a manual drill unless the hole is relatively small (like 1" dia or smaller). Depending upon the size of the hole, you might want to consider using a jig saw or air saw. Shane turned me on to the air saw for cutting my inner fenderwells, and it would probably work well for this if you have compressed air available. Another option is a keyhole saw but these don't work too well unless the metal is well supported.
Old July 31st, 2007, 11:03 PM
cdb
Clark Bowen
Actually Ryan, I was putting the hole saw in the drill when I absent mindedly pulled the trigger as I held the hole saw with my left hand to tighten the chuck. My index finger was in the wrong spot and I wasn't paying attention to what I was doing. Quick lesson.
However, thanks for your comments on an air saw/nibbler. I do have compressed air and I wouldn't mind having a nibbler.
Clark
Old July 31st, 2007, 11:23 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Wow, they're more dangerous than I thought
Glad you didn't get hurt too bad.
Old August 13th, 2007, 08:43 PM
cdb
Clark Bowen
Well, I finally cut the hole
I went to a local body shop and he told me to use a hole saw with medium teeth, so as not to clog the teeth with aluminum. and drill it straight down. I also cut a hole in some hard wood, rubbed a bar of soap on the hole saw and inside the hole cut in the wood and clamped it to the wing. I then cut very slowly. It worked great and I finished off cutting the flanges where the outside and the top of the wing meet with a hack saw blade held by visegrips. I then filed everything nice and smooth and rounded.
For the raised portion of the intake the local muffler/exhaust guy took some 2 1/2" mild steel exhaust pipe and bent it to fit. I had the pipe and the Centri Precleaner powdercoated and put it all together. It works great. I held the Southdown rubber fiiting to the wing with rivnuts.
Here are the pictures.
Clark
ID:	10032   Click image for larger version
ID:	10034   Click image for larger version
ID:	10036   Click image for larger version
ID:	10038   Click image for larger version
Name:	P1000290 (2) (2).JPG
ID:	10040   Click image for larger version
Old August 13th, 2007, 10:57 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Clark - Looks good. The block of wood was a great idea.
I've been debating the passenger vs driver's side snorkel. With the air cleaner where it is, the passenger side provides the shortest run. But some people say that it obscures your view. I've thought the optimum would be to relocate the air cleaner over to the driver's side, and run a DS snorkel. But I haven't scoped out how difficult that would be. There just seems to be an awful lot of hose to get to the air cleaner and then to a snorkel.
Old August 13th, 2007, 11:15 PM
cdb
Clark Bowen
Ryan.
I don't find there to be an issue with it blocking the view. There is about 2" between the snorkle and the window frame and I don't even see the snorkle when looking that way. I liked the idea of a shorter hose and that is why I used the passenger side. The precleaner, however, does look like a small spacecraft is trying to land on my softtop.
Clark
snorkel, wing
Mantec snorkel through wing on a NAS truck? dmarchand Misc. Chit-Chat 22 January 16th, 2009 04:11 PM
Wing top Snorkel mounting 1995 d-90 3.9/petrol Overland90 Defender Technical Discussions 3 September 11th, 2008 04:58 PM
Wing Top Protectors with Antenna hole? seattled90 Defender Technical Discussions 8 September 21st, 2007 01:11 PM
Building my own snorkel - JackW Defender Technical Discussions 7 March 6th, 2006 01:39 PM
Homemade snorkel Davis Misc. Chit-Chat 11 June 22nd, 2005 08:28 AM
