Custom storage drawer source - Defender Source
Old March 22nd, 2006, 07:55 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
I've been doing a bit of research on a rear drawer storage sytem for my D90.
I could build a wooden box - but I really need good security and strength.
I also thought about the Tuffy route - but have heard pros and cons.
Here's a source I found...
http://www.customdogtrailers.com/gal...y.asp?PG_CAT=9
I have them pricing out a unit for me right now that'll be about 8.5" (h) x 32" (w) x 40" (l) - exact width will be determined by the shop drawings as I want to be sure the drawer will clear the door hinge .
I plan to install ply w/carpet (or rubber) on top of the box and wheel wells.
If anyone has a thought on size or layout or whatever - let me know..
Paul
Old March 22nd, 2006, 08:29 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Looks promising. Let us know.
Old March 22nd, 2006, 11:42 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
Don't you have a drawer in the back of your truck?
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old March 22nd, 2006, 11:58 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Funny--I am in the middle of designing and building mine--I found an interesting write up at :
http://home.off-road.com/~cruiserhea...er/tlcbox.html
except I am using all steel. Same basic dimensions that you mentioned--I am waiting on warm weather. If anyone knows where to get good drawer slides for cheap I am looking for 2 in the 36-40" range--most I have found are in the $125/pair range and I sure would like to find something closer to the $75 if possible (salvage/used is just fine with me).
Old March 23rd, 2006, 01:01 PM
WestTexasDefender's Avatar
WestTexasDefender
Sam Allen
'97 LE #234
I've been thinking of having TruckVault build one. They seem to be strong enough to put a lot of weight on top and they are very secure. http://truckvault.com/
Sam
Old March 23rd, 2006, 01:11 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Of course!
Mcmaster carr has them.
How heavy is that going to be?
Old March 23rd, 2006, 11:52 PM
surf110's Avatar
surf110
Ze
130 Project
I got a quote for a box from Truckvault and they wanted $900 to make one for the D.
They said if the box didn't fit I couldn't return it since i supplied the dimensions.
Old March 24th, 2006, 07:15 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
The Truck Vault is a nice system - I had one in my Expedition - it fit very well and looked great. Truckvault does not use drawer runners - they use a plastic friction glide where the bottom of the drawer glides over.
This go around I wanted to find a heavy duty unit made out of metal or aluminum.
Crow River (the link above) Quoted me $688.00 + shipping for a single drawer storage system (od 41"x32"8.5")
All aluminum, all-welded main construction, Diamond plate drawer fronts, hd rollers, folding locking T-handle.
I think I may have them bend up a couple of pcs of aluminum to add to the door sills where I cut back the carpet.
In about 4-5 weeks I'll post some pictures...
Paul
Old March 24th, 2006, 08:08 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
What I did on my DI is a slide out Pelican gun case. I used the slide out rails from an IBM Netfinity 7000 server that can hold up to 125 lbs. The nice thing about it is that my tools won't ever get wet using the Pelican case so I don't have to worry about water crossings. Just a thought.
John C.
Old March 31st, 2006, 08:11 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
Looks like Crow River built my new drawer box in record time (less than a week).
Here's a couple picture - I'll post more after I install...
Name:	box closed.jpg
ID:	5296   Click image for larger version
Old December 12th, 2008, 01:04 AM
tommyd's Avatar
tommyd
Tom
LR3
new drawer systems from Adventure Trailers
Thought I'd try and get this thread going again. . .
Anybody else have storage system ideas they'd like to share? I'm thinking about a system for the 110. I like the ones from African Outback and Black Widow (pictured below left), but they're heavy and expensive to ship.
I know about the Tuffy system, but Marchand says the top is too thin to bear much weight. (I like his solution though - strengthening the top with a sheet of Lexan..)
These new ones from Adventure Trailers look promising though (pictured below right, in a disco I think):
http://www.adventuretrailers.com/drawer.html
Anybody out there that's made their own?
Old December 12th, 2008, 08:35 AM
xrover's Avatar
xrover
Len Cater
1997 D90
I used a discarded photocopier base (Canon) as they are strong enough to hold a 300lb copier on top of them. I primed and painted it black, had a matching tuffy lock installed (keyed to my tuffy storage/speaker box) and then glued on black carpet. It is only 9" high, and about 2'x2' but it allows someone to still get by to the 2 rear seats I have, and does interfere with the legs of the seats. I was more interested in a vault versus massive storage.
Check out the dumpster at your local Canon Office Equipment supplier. They chuck these like they are going out fo style. Make sure you get the metal ones and not the press board type.
'97 D90 NAS
'06 Argo Avenger
Old December 13th, 2008, 02:39 AM
tommyd's Avatar
tommyd
Tom
LR3
Originally Posted by tommyd
These new ones from Adventure Trailers look promising though:
Got a message back from Martyn Davies (Adventure Trailers). He said if he had a minimum order of 5 that would lower the cost by about 30%.
Need four more people interested in a drawer setup for their 110. Anybody?
Interesting idea! Thanks, Len. Any pics?
Old December 13th, 2008, 11:53 AM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Mario from Adventure Trailers is taking measurements on my 90 today to come up with the correct drawer dimensions. The AT drawer system is pretty slick and is about 30% lighter than building it out of wood. They are using top notch slides and latches.
Old December 13th, 2008, 06:49 PM
tommyd's Avatar
tommyd
Tom
LR3
Nice. I'll be anxious to hear your impression once you get them. You have one of their trailers, right?
Old December 14th, 2008, 02:13 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I have a Tuffy in the back of my 110.. Fit's like a glove on the sides and the top is level with the top of the fender wells after the installation of a piece of 1/2" plywood. It's short enough that it won't interfere the the fridge that will go between the two rear seats, on either side of the fridge will be th ewater pump and the inverter.
Keith
Big, Red and ... aaa Red..
Old December 14th, 2008, 03:16 PM
tommyd's Avatar
tommyd
Tom
LR3
Thanks, Keith. Any pictures?
Old December 15th, 2008, 05:15 PM
xrover's Avatar
xrover
Len Cater
1997 D90
Here you go. Taken with a camera phone so not that great but gets the point across. They are all steel boxes, bolted through the wheel well. Obviously limited in size but I wanted something I could put a notebook in and yet deter a spontaneous thief.
ID:	16892   Click image for larger version
'97 D90 NAS
'06 Argo Avenger
Old December 15th, 2008, 08:54 PM
tommyd's Avatar
tommyd
Tom
LR3
clever.
Old December 15th, 2008, 11:37 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I'll try and get a couple tomorrow. Short days, shipping, making product, 0 degrees and an extremely gimpy right foot are slowing me down a bit...
Keith
Custom Lockable Rear Storage Drawer Manimal For Sale - Parts 11 October 12th, 2008 07:43 PM
New Storage Drawer for D90 Davis Misc. Chit-Chat 1 June 13th, 2006 09:44 AM
Storage Box for the Holiday? Troys For Sale - Parts 4 December 16th, 2005 11:59 AM
D90 Storage Boxes chrisvonc For Sale - Parts 8 January 27th, 2005 02:19 PM
Pickup cab and custom cage dave_lucas For Sale - Parts 11 January 7th, 2004 10:12 PM
