Custom Axle Buiders - Defender Source
Old August 4th, 2008, 05:41 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Custom Axle Buiders
Anyone have any experience building custom axles for their D-90. Any reputable builders with LR knowledge? Considering a couple of options regarding upgrading.
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old August 4th, 2008, 08:23 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Portals???
Legend in My Own Mind.
Old August 4th, 2008, 09:44 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Portals are a little too extreme for me. I'm thinking more on the lines of custom dana 60's or 9". I am thinking of the toy 3rd dif swap, but if I'm spending the money I want to see if there are better options out there.
Old August 4th, 2008, 10:07 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
What size tires are you running and how hard do you really wheel it? These are the honest questions you should ask yourself.
Old August 4th, 2008, 10:12 PM
Tisdale had a set of 9" with 60 outers and custom tubes made for his 94. I think they were done by Rockware... but I already know your feelings about them. I am pretty sure his were north of 15K.
Old August 4th, 2008, 10:52 PM
Talk to Keith at RoverTracks
Old August 4th, 2008, 11:31 PM
madcowdungbeetle
Carter
I've put a D60/D70 under my Disco.
I'm considering building a set of 9-60's for my D90 this winter.
I think Keith's Toyota kit is an excellent setup if you plan on keeping the truck on anything less than 37's.
Old August 5th, 2008, 09:26 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
hey Joe,
If you are seriously considering this, we should talk about the options. There are a lot of things that go into this decision that need to be ironed out in order for you to be happy. PM me and we can exchange phone numbers. Hope your doing well.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 5th, 2008, 11:18 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Don't know what your end game is, but you could consider a matched pair of front and rear salisburys.
Old August 5th, 2008, 11:47 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
For what it is worth, here is my .02. Looking at your avitar it seems like your rig is very well suited for street and trail. In the grand sceme of things going with custom axles will end up being much more than just the axles to obtain similar streetability. If you want to keep that as a major part of your D90 enjoyment go the toy route. Dave and I can attest to long periods of doing and re-doing aspects, ultimately I personally had 3 builders involved with my 9/60s. Secondly I personally feel that you do not need that much hardware on your D90 unless you are seeking trails that require 37"+ tires and you are committed to all of the other modifications that come along with going down that path and are currently breaking parts regularly. Look at Dave's truck 3 years ago and look at it today, that is what he wants. For me, the more modified my D90 got the more it sat in the garage and traveled on the trailer and the less I drove it around town (switching tires is a big pain!), be prepared for that reality.
If you are set on custom axles and looking for someone to do it for you with LR experience I'd suggest off the top of my head:
Keith-Rovertracks (salsbury and toy converstions)
Matt- Rockware (can build anything)
Sunray Engineering (not sure they are doing axles anymore)
FWIW- If I were to do it over and start today I'd get the 9" housings and knuckles from Spidertrax, the 3rd members from Hi9 and have Matt build them to spec. Those axles would be spendy though.
Old August 6th, 2008, 01:31 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
For up to 37" tires, Keiths Toy diff conversion is tough to beat. It's fairly easy and reasonably priced. I've done several and they've turned out well. I'm currently building a 110 that will be wearing only 33" tires. The customer opted for 4.88 gears with a front toy conversion and a rear Salsbury/D60 hybrid. The t-box has been rebuilt with 1:1 high range gears. The truck is being built to tow a boat and be daily driven as well as having excellent low range gearing for off road use. High range gearing will be very slightly higher than stock (1.5%), but the low range gearing will be about 38% lower than stock. By creatively combining t-box ratios and diff ratios it is possible to end up with a truck that is very well geared for off road use while still being streetable
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old August 6th, 2008, 02:34 PM
outfield
Steve
1995 D-90 SW #351
Dynatrac has bolt-in Dana 60's for a Defender. They have a delaer in the UK that has been ordering them for a while and wouild be happy to sell some in the states.
Old August 6th, 2008, 05:15 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
That's silly.
They make and awesome axle, but for a rig you plan to drive daily, I would have serious reservations about that kind of weight. Especially if the tire size we are talking about is 37 or less.
Edit: Tiz nailed it. He's right on everything.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 7th, 2008, 02:52 PM
slorocco
Dan Prasada-Rao
Yeah, the matched salisbury's are kinda silly but that's where I am. I already had a rear with the series 4.7 gearing. I found a front with the same gearing and decided to just do it. It's actually turned out cheaper than some of the alternatives.
Old August 7th, 2008, 03:05 PM
outfield
Steve
1995 D-90 SW #351
Buck,
It looks like you are running 37's, what type of front CV's are you using? Do you run a Detroit in the front, ARB or?? How about the diff gearing and T case gearing?
I'm real worried about my front shafts after seeing how small they really are. My CJ-5 with WARN shafts in the DANA 30 make the Rover stuff look really puny. So far my front shafts have lasted 2 years, but having something stronger is good piece of mind.
Old August 8th, 2008, 09:15 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Did you upgrade the rear axles and weld on new front outers? That's the problem with the sals. Without serious mods, they really dont do any good except for making your truck heavier and your wallet lighter. Not trying to be negative, Kieth makes a killer upgrade for the rear and your r+p is seriously stout.
Buck,
Hey,
I run 40s with Dana 60 outers. You should be worried about the stock stuff, because it is uniquely weak. But like stated earlier, the toy conversion is surprisingly strong. Its no dtrack 60, but will handle 35s without worry.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 16th, 2009, 07:57 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
As an update, I think I have settled on Keith's Toy Upgrade. now the quesiton is ARB's vs E-Locker.
any thoughts
Old January 17th, 2009, 01:24 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
any thoughts
Hi Joe,
Have you seen that I have my rear rover 9 for sale? It's bolt in with an ARB and third member. I know you and would knock some money off the price. You won't find a better deal anywhere, by a grand or two. Plus some of the $$ is going to Kieth anyway. If you did my rear and toy front you cound rock 37's without any worry. I even have my front for sale too but I think that is going a little too far for what you want to do.
Check it out in the for sale section and let me know if you are interested!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 17th, 2009, 09:11 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
Hi Joe,
yep, somebody buy these axles.
Old January 17th, 2009, 12:22 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I am really surprised that the rear hasn't sold. Many people interested but only one offer and it was for a D2 so it wouldn't fit. Probably the economy...
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
axle
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
Custom Rovers North D90 Roof Rack Barnett Childress For Sale - Parts 0 October 9th, 2005 07:29 AM
new rear axle rolaro Defender Technical Discussions 8 January 26th, 2005 11:34 AM
Pickup cab and custom cage dave_lucas For Sale - Parts 11 January 7th, 2004 10:12 PM
