Curious knocking noise - Defender Source
Old March 27th, 2005, 02:47 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Angry Curious knocking noise
We're talking discovery 1 here but the drive train's the same
What the problem is:-
A knocking sound directly related to road speed, 2 knocks per wheel revolution, I marked the tyre and counted the knocks.
What I've checked:- oil levels in the transfer box and axles, wheel bearing play.
I've jacked up each corner of the car and ran the engine for a short period with the car in gear and can't reproduce the knock so then I tried gently applying the brakes to introduce some load. still no knocking noise. I've jacked up each side, two wheels off the ground and run the engine in 1 st & 2nd with and without the diff lock engaged, still no noise. I jacked diagonally opposite corners, ran the engine as above still no noise. I'm stumped, don't want to strip down axles 'cause the noise seems to be coming from the middle of the truck but noise can transfer itself in curious ways. To my mind two knocks per wheel revolution would rule out anything further up the drive train than the diffs which are 3.54:1, the knock is at too slow a frequency. I'll probably end up striping an axle but which one?
Is the problem in the axles?
Any input would be appreciated
Mike Hammond
Old March 27th, 2005, 09:17 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Checked the u-joints and greased both them and the driveshafts?
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 27th, 2005, 11:59 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Remove one driveshaft at a time and drive. My guess it is actually a U-Joint.
Old March 27th, 2005, 02:29 PM
mikeslandrover
Mike Hammond
I'll grease the drive shafts and drain the oil out of the diffs and see if anything sparkley comes out. I hate removing props, one got jammed once then came off suddenly and I caught it with my face, had the world"s fattest lip for about a week, kind of sore I can tell you.
I checked the oil in the transfer box, nothing sparkley in there, so that's a relief.
The Discovery is a pain to work on compared to the 90 & 110, can't high lift jack it, can't rip the floor out for easy access and there are more wires than you can shake a stick at when it comes to an electrical problem!
233000 miles and still clonking along
Mike Hammond
Old March 28th, 2005, 07:06 AM
mikeslandrover
Mike Hammond
Well it's sorted.... the bloody wheel nuts were starting to back off
Driver's side front were only hand tight and the wheel was starting to move on the hub enough to polish the hub but not enough movement to be detectable when rocking the wheel to check the bearings. something to add to the weekly checks - are the wheels on tight?
Mike Hammond
Old March 29th, 2005, 02:01 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Sorry I didn't read this earlier. The same thing happened to me last summer. I was sure it was the U-joint but it turned out to be a loose wheel!
-Steve
Old March 29th, 2005, 06:09 PM
mikeslandrover
Mike Hammond
Well I was all set to rebuild the transmission & the axles , scary how I always jump to the worst case scenario
On the plus side, during all the time I'd set asside to rebuild all of the above I rebuilt the rear wiper motor and that worked brilliantly the shaft had siezed into the wiper motor body and everything ground to a halt
So all thats left to do is weld up the rust perforations in the rear of the chassis, replace the springs & shocks
and it'll be just like new ... PROPER JOB!!!!( said loudly with a west country accent)
Thanks for the helpful suggestions
Mike Hammond
Transmission noise help... reb78 Defender Technical Discussions 5 September 22nd, 2008 05:28 AM
Knocking Noise tron Defender Technical Discussions 18 October 21st, 2006 11:08 AM
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
