Curious..Diesel to Gas conversion - Defender Source
Old February 1st, 2016, 06:42 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Just out of curiosity...what would it take to convert a 2.5TD with a L77 to a gas V8? I do love the diesel, but it is soo slow...and yes I could upgrade to a 300TD.....
For some of the motors I assume they would mate up to a L77 or would you have to change the Trans too? What else would be required?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old February 1st, 2016, 07:02 PM
You have to change the gearbox. They are different for the diesels. New motor mounts and change over everything. If you have to ask.....
Old February 1st, 2016, 07:29 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you purchased an old Discovery you could use everything engine/transmission. The V8 bell housings for the manual transmissions are getting harder to source. You would have to upgrade your wiring harness to accept the new electronics unless you went the carb set up. As stated above you would also have to change your motor mounts also. It is pretty easy to do but requires a bit of work.
Land Rover 110
Old February 1st, 2016, 07:32 PM
Thats not such a bad idea. Especially if you go with the Lokar adapter....
Old February 1st, 2016, 08:54 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Interesting...I guess the 300TD or a newer TD5 or such would give it more get up and go with less issues...would still have to change the box..but not a big deal...was just curious...
Old February 2nd, 2016, 07:23 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I would highly recommend you find and drive before making a decision based on speed. The 300 may not be your idea if speed either.
conversion, diesel, gas
gas tank conversion to diesel review kim Defender Technical Discussions 20 March 20th, 2013 06:48 PM
Just curious Campbell Defender Technical Discussions 11 June 17th, 2011 07:48 AM
Just curious what you guys think of the new baby Range Rover? Neil McCauley Misc. Chit-Chat 13 November 19th, 2010 07:40 PM
Random Connection? Curious...... Flagg Defender Technical Discussions 12 April 14th, 2009 01:30 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
