Curent silver relay part #? - Defender Source
Old November 12th, 2012, 08:39 PM
wantone
Rick Thompson
94 ST #1222
Did a search could not find it. Anyone know current bosch # for the silver relays? 94 d90.
Thanks!
Old November 13th, 2012, 09:48 AM
wantone
Rick Thompson
94 ST #1222
nevermind, found the napa number.
Old November 13th, 2012, 10:01 AM
Old November 13th, 2012, 10:07 AM
wantone
Rick Thompson
94 ST #1222
josh,
did the ar 274 relays from napa workout?
thanks
Old November 13th, 2012, 10:12 AM
Yeah they're fine. I can't remember what number they were so I was seeing if you'd just bump this thread with the info you found.
Those are the cross-reference Mercedes ones or something, right?
Old November 13th, 2012, 10:15 AM
wantone
Rick Thompson
94 ST #1222
the napa ar 274 number comes up as a relay for several things like turn signals, stereo relay etc. when i do a seach for d90 fuel pump relay something totally different comes up. i called napa and the guy on the phone didnt really know anything...
Old November 13th, 2012, 02:07 PM
wantone
Rick Thompson
94 ST #1222
yep. napa AR 274 works like a charm. about $20
Old November 13th, 2012, 03:49 PM
maleger
Marc-Andre Leger
Which one did you choose ? As you mentionned, it is listed for several applications, but the silver Bosh relay near the EU is for the fuel pump or something like that isn't it ?
Old November 13th, 2012, 03:52 PM
wantone
Rick Thompson
94 ST #1222
I just went in & asked for part # ar274, it is the same relay for all the applications.
Old November 13th, 2012, 03:59 PM
maleger
Marc-Andre Leger
Old September 17th, 2017, 02:13 PM
aosias's Avatar
aosias
Alexandra
1995 D90
These will work for the silver relays?
https://www.napaonline.com/en/p/ECHAR274
I read another thread where you had to pull the Hella light relay when you shut the truck off.
part, relay
Silver Relay / Silver Relays rijosho Defender Technical Discussions 18 January 8th, 2012 01:07 PM
Flasher Relay Part Number for 97 d90? KKilo23 Defender Technical Discussions 3 May 20th, 2010 09:45 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
