Cummins in a defender - Page 9 - Defender Source
Old December 22nd, 2016, 04:25 PM
Al Blue4.6l's Avatar
Al Blue4.6l
Allen
1991 D90, 2006 LR3
Originally Posted by Rocky View Post
Its not going to be cheap. See post 32 in this thread, where they put a ISF 3.8 into a j**p. Bruiser Cummins ISF Gecko Build - Page 4
Old December 22nd, 2016, 05:21 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by mongosd2 View Post
gotta link to the build?
I've just been following pics on IG: https://www.instagram.com/ianfromxtreme/?hl=en
Old December 22nd, 2016, 06:02 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Jeep frame?
Sheep in wolf's clothing...
Blah.
Old December 22nd, 2016, 06:44 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I saw that JK frame and at first was WTF?! But since he is doing the suspension over anyway and here in the US a JK frame is a lot easier and cheaper to get I started getting over it. And the LR frame design of holding debris in the front horns, bulkhead outriggers and rear crossmember isn't all that great either.
I do wish he as staying with an LT230.
So... will it be registered as a LR or a JK.... as he's swapped the frame ?
Either way, interesting to see how it turns out & performs. Getting the frame hot dipped would be the best option after the rework... maybe ?
Old December 22nd, 2016, 08:44 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2516
As long as the frame could handle that grunt.
For a diesel, I wouldn't say that it didn't look fun to drive!
"Barry is correct!"
Old December 24th, 2016, 08:26 AM
Chris B
72 + D1 drivetrain =?
Started to see adverts on TV for the Cummins repower program with these ISF engines.
Old December 25th, 2016, 10:12 AM
Nice. I am seriously considering this for my next truck
Mark Kellgren
KM4BOR
Old December 31st, 2016, 02:39 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
New vid:
Old January 11th, 2017, 09:56 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Anyone hear of a price yet? They also say "first in a series of new engines..." so it really makes me wonder what engine #2 is!
Old January 11th, 2017, 10:29 AM
Chris B
The 2.8 ISF has a bigger brother.
I'm a little concerned about gearing given its max rpm of 3200.
As for price. Nothing yet. Engine cost is just the start of the process.
Old January 11th, 2017, 11:20 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am not worried about the 3200RPM---it makes 267 ft-lbs from 160-3200 and that is what i am after for my towing. I can get a brand new NV3550 with gear ratios of
NV3550
First Gear 4.01
Second Gear 2.33
Third Gear 1.39
Fourth Gear 1.00
Fifth Gear 0.78
Reverse 3.57
R380: (slight difference in 1st gear between TDI/V8 but not showing here)
1st: 3.692
2nd: 2.132
3rd: 1.397
4th: 1.00
5th 0.770
Rev: 3.429
So assuming the same gear ratio on the transfer case, everything aligns great as far as my set up requirements.
A grand new box costs $1250 if I went new. Then there are a lot of other costs ranging from cooling to fueling, but still worth it for me as long as the engine is in the $5-6K range which may be hopeful.
Old January 11th, 2017, 11:23 AM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Just to add another .2 cents to the thread. I was talking to the Cummings guy at Overland Expo. They had a 2.8 in a Jeep as a test truck. They were hoping to complete the engine certification soon and have this motor as 50 state legal for all light duty trucks model year 99 and older. It will be a plug and play unit with several optional wiring harness available. They have already worked with Advanced adapters and will have a number of different vehicles that it will drop into including rovers up to DII. They are looking at it to be a easy diesel option w/MPG is the mid 30's. They did not have a firm price but said it would probably be similar to the cost of an LS1 crate motor.
For what it's worth
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi 5 speed SoftDash (My Son's)
"Be the person your dog thinks you are"
Old January 11th, 2017, 11:49 AM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Think of all the free time you would have...
Old January 11th, 2017, 12:14 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Since the LS1 was discontinued a while ago, I will have to assume in the $5k range as that was what they sold for back in the day... But I know, your guess is as good as mine...
They did say right about now they would start to release that info...
Old January 11th, 2017, 12:30 PM
It is 3600, not 3200 Basically the same required gearing as a Rover TDI. An NV3550 or R380 and 1.2 t. case will be perfect.
https://cumminsengines.com/uploads/docs/4971326.pdf
163 hp @ 3600 RPM
266 lb-ft @ 1800 RPM
Old January 12th, 2017, 07:12 PM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
Saw this today:
Old January 12th, 2017, 07:35 PM
D90Overkill
David Frank
1995 ST #2516
Prettiest box I've seen in a looooong time ;-)
"Barry is correct!"
Old January 12th, 2017, 10:44 PM
Surf90's Avatar
Surf90
C.S.
He said he's putting one in a 110 for a client. Can't wait to see
Old January 29th, 2017, 10:29 AM
scrubs
henery
1974
If already posted please forgive
Mini-Feature: Tom Davies' 1986 Land Rover Defender 110
------ Follow up post added January 29th, 2017 10:31 AM ------
https://m.facebook.com/groups/953826...82384065172136
Old January 29th, 2017, 10:37 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
This video of Tom driving it has probably been posted already but its worth a repost:
https://youtu.be/5n-XqSb0iyI
SIII Cummins 109 - Timm Cooper build - 29K Tawayama For Sale - Vehicles 135 March 17th, 2014 07:37 PM
Defender vs Cummins Powered Ram Pickup tug-a-war flananuts Misc. Chit-Chat 3 October 10th, 2013 07:56 AM
Dodge Ram Cummins vs. Defender 90 Tug of War coffee Misc. Chit-Chat 14 September 21st, 2013 07:23 PM
Cummins Ram For Defender Anyone?? sincityrover For Sale - Vehicles 3 May 1st, 2007 11:35 PM
Gaguing Interest: Immaculate 109 Wagon with Vortec V6 or a Cummins 4BT diesel dieselcruiserhead For Sale - Vehicles 6 October 28th, 2006 11:32 PM
