Cummins in a defender - Page 5 - Defender Source
Old October 11th, 2016, 11:22 AM
Yes, I've seen it. With the 3.8, you have similar problems as the 6BT, in that you need really high gearing, due to the low redline. You will want as tall a high gear as possible in the gearbox plus a 1:1 transfer case ratio. Do the gearing math before anything else.
Old October 11th, 2016, 04:13 PM
diamonda
Andrew Diamond
1985 V8 90
Originally Posted by Rocky View Post
The 6.7 or 5.9 Cummins diesel probably weigh three times a Rover V8 engine. That can't be good for handling, suspension or handling.
It actually works ok because most of the engine is behind the axle and most of us run Salisbury front axles with their extra load capacity. It actually handles better than a standard V8 SW, probably partly due to it being freshly built from the chassis up with uprated bushes /springs etc. Extra weight over a Tdi is pretty comparable to having a winch and winch bumper but in a better location.
Andrew
Old October 11th, 2016, 04:45 PM
diamonda
Andrew Diamond
1985 V8 90
Smile CLR video
Originally Posted by don View Post
Wow!
What's he running for tranny? I would love to hear and see a vid of that thing running.
Coming soon, just waiting on the new Go Pro! Tweaked it up to about 500HP with an edge tuner last week so sounds good!
Andrew
Old October 11th, 2016, 04:47 PM
I want a 5.9 in my D90
Old October 11th, 2016, 05:03 PM
diamonda
Andrew Diamond
1985 V8 90
Here's some pics of Simon Cochrans awesome build, another member on the FB Cummins Landrover group. 5.9 6BT running compound turbos and 60psi of boost, air suspension, 101 FC axles, Porsche 6 pot calipers and every other mod you can think of...
Andrew
Old October 11th, 2016, 05:07 PM
diamonda
Andrew Diamond
1985 V8 90
Engine bay pic...
Old October 12th, 2016, 06:57 AM
LR Max
Thomason, Max
1973 Series 3 109
Originally Posted by rovertek View Post
Totally agree with you ! now the big question
nv4500 or 4l85e ?
i spoke to a bunch of adapter company's and since its a isf common rail they have not made anything for that engine but i'm assuming its a SAE# 3 bellhousing which i could adapt to
Go look at an Allison 1000 series. They make all kinda stuff. Might be a bit more expensive, but probably cheaper than home brewing something. I know they make 2000 series transmissions to put behind the 4.5s. So I can only assume the 3.8 would share.
Old October 12th, 2016, 07:07 AM
DIESEL all the way....
I work with isb /isl/isx all day great power and reliable the new rear geartrain engines are much quieter ..common rail is the way to go but there way too heavy in my opinion so now theres the 2.8 /3.8 isf i think these will be great engines for defender use now we just have to find someone willing to take on that project....who could it be ?
?Rdavisinva?
Old October 12th, 2016, 07:55 AM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
Andrew
Thank you for sharing the photos, Andrew.
That is "dead sexy"
I like the green flames, too !
Anyway, gives me hope for mine...
Thanks, again.
__________________________________________________
shoefnik wrote: "Itís funny how that moral line you draw for modifying your Rover changes as your needs change."
Old October 12th, 2016, 08:05 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Have to do some measurements that trans is huge ...don't want to cut up my 130 that much. But if i could get it in there i'm all for it
Sent from my SM-G920P using Tapatalk
No Mall crawler here
Old October 12th, 2016, 05:37 PM
Gaz69
Garry
97 Defender 130 Extracab-6.6Duramax
Allison
HTML Code:
I have the allison 1000 in my 130 but i'm running a Duramax. I also lifted the body 2.5 inches to get the motor/trans back further. I'm akso thinking about setting up a cummins / allison combo but i have to complete my rebuild 1st.
Gaz
Old October 12th, 2016, 05:42 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Gaz we need pictures stat !
Duramax allison sweat combo ...
Old October 12th, 2016, 06:01 PM
I can see an Allison 1000/duramax in a 130 but that's a mighty lump....
Old October 12th, 2016, 06:43 PM
Gaz69
Garry
Guys,
Don't want to hijack this Cummins thread but as there are inquiries RE: Allison i feel it is relevant. I have my own build and phot'os in Truck Build-up's & Restores folder. I haven't updated for a while but look for my username.
Cheers
Gaz
Old October 12th, 2016, 06:52 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
I guess ill have to start a build thread ..here's side by side 300tdi to 3.8 isf......
Old October 12th, 2016, 07:44 PM
Flywheel housing looks crazy deep
Old October 12th, 2016, 08:00 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
The bell is similar to ISL ..sae#3
In pictures it looks much deeper ..
Its about 2" from faceof flywheel to edge of bellhousing
Old October 13th, 2016, 07:17 AM
LR Max
Thomason, Max
1973 Series 3 109
Yep. Looks like a SAE 3 housing.
Wonder if it would be easier to adapt the rover bellhousing and flywheel to the Cummins. Hopefully just drill a few holes. and roll with the rover starter.
Old October 13th, 2016, 08:20 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
At 443 ftlb of torque at 1300 rpm the r380 would not live very long even with upgrades .
Old October 13th, 2016, 10:06 PM
Cummins Chinese factory with Foton Motor. https://youtu.be/pRqrXM6tnig
SIII Cummins 109 - Timm Cooper build - 29K Tawayama For Sale - Vehicles 135 March 17th, 2014 08:37 PM
Defender vs Cummins Powered Ram Pickup tug-a-war flananuts Misc. Chit-Chat 3 October 10th, 2013 08:56 AM
Dodge Ram Cummins vs. Defender 90 Tug of War coffee Misc. Chit-Chat 14 September 21st, 2013 08:23 PM
Cummins Ram For Defender Anyone?? sincityrover For Sale - Vehicles 3 May 2nd, 2007 12:35 AM
Gaguing Interest: Immaculate 109 Wagon with Vortec V6 or a Cummins 4BT diesel dieselcruiserhead For Sale - Vehicles 6 October 29th, 2006 12:32 AM
