Cummins 6bt - what tranny? - Defender Source
Old April 15th, 2010, 07:03 AM
T.U.
Pete
94 D90
Question Cummins 6bt - what tranny?
I have a chance to pick up a cummins 6bt fleet motor with low miles for short money.
I'm considering doing conversion in my 90 but I'm not sure what transmission would hold up to it.
Right now Run an LT 77, but will that hold up to the torqe?
Old April 15th, 2010, 07:33 AM
LRover's Avatar
LRover
J. Michael McCaig
The NV4500 would be your best bet for a transmission. Others here can speak to the engine choice better than I. The 4bt has been done but I'm guessing the 6bt is going to be way too big for your 90.
Old April 15th, 2010, 08:03 AM
I think you'll find the 6BT awfully heavy. You can likely make it fit, somehow, but I don't think you'll like the way the truck handles afterward.
If you have to have a diesel, a 300 Tdi is a very good choice.
Old April 15th, 2010, 08:12 AM
T.U.
Pete
94 D90
I'd love a 300 tdi, but I don't think the wallet would handle it.
Old April 15th, 2010, 11:08 AM
The 6BT conversion will cost you a lot more. It is a very involved and complicated engine swap. You need to change the entire driveline to handle the torque. You need modify a lot to make it fit and work.
Old April 15th, 2010, 12:11 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Even a 6AT will test the limits of the chassis. I would wager that you would add 20 pounds of properly placed steel plate to allow the chassis to survive with a 6BT. Due to the size of the engine the front driveshaft will likely be a two piece.
Keith
Big, Red and ... aaa Red..
Old April 15th, 2010, 12:19 PM
JL put one in a 109, but he indicated at one point IIRC that the coil suspension of a 110 causes issues. I don't see how it would fit in a D90 as the motor is so long.
Old April 15th, 2010, 01:17 PM
leaterwood's Avatar
leaterwood
Cleveland T. Leatherwood
95 D90
Better start looking into upgrading your axles and transfer case... something as stout as a Rockwell axles and Atlas transfer case would handle that torque. A lot of money and custom fab work..... Good Luck
A little duct tape and a lot of paint and no one will ever know
Old April 15th, 2010, 01:47 PM
T.U.
Pete
94 D90
Perhaps I am a bit too enthused about this.
Old April 15th, 2010, 06:58 PM
exmod110's Avatar
exmod110
Don Lang
If the engine is a "good deal" buy it and resell it to cover most of a 300tdi!!
85 exmod 110 rhd 300tdi
Old April 15th, 2010, 09:18 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
yup.......enthusiasm is a good thing, you just need to redirect it a little.
Matt Browne
Old April 16th, 2010, 04:55 AM
T.U.
Pete
94 D90
Maybe.
Old April 19th, 2010, 11:00 AM
rovertrader's Avatar
rovertrader
Dale
should easily cover the 300, and if you consider all the items listed above, you could use the 6BT for an end tabel, buy the 300 and still be thousands to the good, and be driving it getting 25 to 30 mpg instead of fitting and breaking parts. Hard to hear, but sadly, ask me how I know...
Cummins 6BT in a 110 pickup... IPSC_GUY Misc. Chit-Chat 7 December 30th, 2009 06:23 PM
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Wanted, NAS 1995 D-90 (Tranny) Transfer case Roverville Wanted 3 November 28th, 2005 02:14 PM
Wierd tranny question? D90user Defender Technical Discussions 6 November 15th, 2005 10:17 AM
Tranny leak?? mspell Defender Technical Discussions 3 September 8th, 2004 12:43 PM
