cruise control? - Defender Source
Old October 11th, 2005, 09:58 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
cruise control?
Is there a kit or retro fit for a 95 D? I am considering installing one since I can't stop driving it everywhere...
Bill
Old October 11th, 2005, 10:42 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I once used a brick to lay on top of the gas pedal, but that was in a VW bus on my way to a dead show.
Old October 11th, 2005, 10:58 PM
cruise what?
Old October 12th, 2005, 01:17 AM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
I had a bus driver use the same method on an old dbl decker. We get on the autobahn, brick on the pedal, feet up on the wheel, lean back and roll a smoke.
Insert pithy quote here.
Old October 12th, 2005, 09:37 AM
Disco_Stu
Stuart
2000 DII
Found this in the archive area:
See if you can locate the June '03 issue of Land Rover Monthly. There is an article starting on page 100 about installing the Vehvac cruise control system (made by an American company called Rostra); supposedly it can be installed on any model of Rover.
-Stuart
Old October 12th, 2005, 05:20 PM
Troys
Troy Smith
1995 D90 SW
William
I took one off my truck after I purchased it. PO had it installed. If I can find it you are welcome to it. Will be the weekend before I can rumage around the shop though.
Troy
Old October 12th, 2005, 05:32 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Cruise heck, I want a tilt wheel.
Old October 12th, 2005, 05:57 PM
I would be interested in cruise if anyone has an ideas.
Ron
Old October 13th, 2005, 07:06 AM
Marc Weinstein
Marc Weinstein
defender 90 '94
Can use brick or "choke" cable but in either case one must remember to tun it off to slow down!
Marc
Old October 13th, 2005, 12:05 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Troy,
That woudl be great. Just let me know if you find it and what you need for it.
My size 13 boot works pretty good as a brick but I am lazy.
thanks,
Bill
Old October 18th, 2005, 03:27 AM
Broke It
Dave Butler
99 disco
you can rip one out of a disco at he junk yard just make sure to get all of the peices. for setting the speed a 3 way rocker switch is nice.
99 RR Body Control Module chrisvonc Wanted 0 March 24th, 2006 11:16 AM
Wanted: wiper control cdnpaul Wanted 1 February 12th, 2006 05:45 PM
300tdi diesel fueling control solenoid Chris Cox For Sale - Parts 1 January 2nd, 2005 07:22 PM
Hot/Cold - Blue/Red Heater control cover SFD90 Defender Technical Discussions 5 October 21st, 2003 06:31 PM
