Crower Cam, upgraded valve springs? - Defender Source
Old March 9th, 2010, 10:37 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am using the Crower 50229 cam in lieu of the 50227 (just for yucks) for my new rebuild. I know that it is recommended to use upgraded springs if the cam lift exceeds .430" which was not a problem for the 50227. The 50229 has a lift of .430 for the intake and .443 for the exhaust. Should I upgrade the valve springs? I know a couple/few of you are using the 50229--did you retain the original springs or can you recommend a different spring? Thanks!
Old March 9th, 2010, 01:30 PM
Only if you are going to run the engine consistently above 5K rpm. Dunno about you but in my truck the engine rarely whirls over 3 grand. The heavier valve springs as you know are to reduce valve "float", which only happens at high rpm.
Old March 9th, 2010, 02:54 PM
springs are fine, you might want to get the billet rocker stands. I did the 230 and had a little taken off the valve guides.
Old March 9th, 2010, 04:40 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I thought changing the springs was to also reduce spring bind, not just the float--I may be wrong about that. I will measure the spring bind before firing it up.
Phillip--where did you get your rocker stands?
Old March 10th, 2010, 06:51 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
You are correct. Nothing to do with float really. It's all about the bind and I think you will get very close to that with the 229 cam.
Matt Browne
Old March 10th, 2010, 08:15 AM
I got them from D&D they are spendy but cheaper than a broke rocker.
Old March 10th, 2010, 09:33 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Thanks, everyone.
Crower CAM - New In Box RedRhinoProducts For Sale - Parts 0 April 13th, 2006 06:06 PM
Crower or Isky cam kellymoe Wanted 0 March 31st, 2006 04:48 PM
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
Cam choice kellymoe Defender Technical Discussions 11 February 20th, 2006 01:04 PM
crower cam not fitting vesparover Defender Technical Discussions 11 July 18th, 2005 11:32 PM
