crower cam not fitting - Defender Source
Old July 5th, 2005, 08:41 AM
vesparover's Avatar
vesparover
brian bertolini
Hey everyone I purchased a crower cam for a buick 215 (rover 3.9) from d&d. The journals on the stock cam were much smaller than the ones on the crower. Mark from d&d said that it was definately the right cam for the rover motor. His father said he'd only seen this happen a couple of times in thirty years. So has anyone had this happen or am I just really lucky?
Brian Bertolini
Old July 5th, 2005, 12:01 PM
I still have the stock cam but do you have a pair of calipers that you can use to measure the 2? I have a cam out and calipers at home that I can measure mine.
Old July 5th, 2005, 01:06 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
They are tapered--silly, but are you checking the same end-to-end?
Old July 5th, 2005, 03:33 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Brian I just installed a Crower cam. Mine fit perfect. What springs did you go with.
Old July 5th, 2005, 06:38 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I also just installed mine without any issues. Runs great. What part number did you get--it should either be the 50227 or 50229
Old July 5th, 2005, 09:03 PM
vesparover's Avatar
vesparover
brian bertolini
It was noticably smaller by eye and by measurement definately smaller on the journals. The cam can only go in one way so I know that's not the problem. D&D said that it has happened before where the motor is actually the problem, and the cam needs to be ground to fit. But they've only seen it maybe twice in 30 years!
Just wondering if it has ever happened to anyone else. It was the 5229 one I believe.
Old July 5th, 2005, 09:53 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Cam bearings are replaceable, and it sounds like yours were for oversized bearings and they ground down the cam. Hmmmm, strange, uncommon, but possible. This sounds like something that would happen to me! Has anyone here replaced cam bearings? I replaced my crank bearings with oversize, but that is because I wanted to make sure my used crank was true so I had it ground. Funny to do that to a cam.....
Old July 5th, 2005, 10:11 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
You shouldn't ever have to use oversized cam bearings, since you generally replace the cam too, and that replaces all of the wear surfaces.
This is an odd situation.
Maybe give D&D another call and find out what the measurement is supposed to be, maybe you got a mis-ground cam? I suggest finding out the tolerances, measuring all the associated parts, so that we can figure out which part is the incorrectly sized one.
And, sorry to sound dumb here, but it's definitely a 3.9 Rover, correct? No previous engine swaps or rebuilds that you are aware of?
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 6th, 2005, 08:22 AM
vesparover's Avatar
vesparover
brian bertolini
Everything was unmolested and stock(3.9). All I can say is I wasn't very happy to have ripped my whole engine apart and then the cam was a no go.
Old July 6th, 2005, 09:50 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
can you take the cam bearing diameter measurements and post them?
Old July 17th, 2005, 10:50 PM
vesparover's Avatar
vesparover
brian bertolini
Hi everyone, ends up crower shipped out a batch of cams that were not machined correctly. I got my replacement installed today with no hangups. Is there a pic anywhere at the reassembly of all the ancillaries. I'm having trouble remembering the order of assembly and where all the brackets go.
Brian Bertolini
Old July 18th, 2005, 11:32 PM
mattdh's Avatar
mattdh
Matt Hurst
brian if you need help on the brackets pm me
Crower CAM - New In Box RedRhinoProducts For Sale - Parts 0 April 13th, 2006 06:06 PM
Crower or Isky cam kellymoe Wanted 0 March 31st, 2006 04:48 PM
Cam choice kellymoe Defender Technical Discussions 11 February 20th, 2006 01:04 PM
changed cam, all gaskets and now it won't run vesparover Defender Technical Discussions 4 July 24th, 2005 09:56 PM
DIY Cam replacement, who's done the job kellymoe Defender Technical Discussions 6 December 17th, 2004 12:37 AM
