Crossmember Delaminating - Page 6 - Defender Source
Old March 16th, 2011, 12:29 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Originally Posted by bjf View Post
Wait you aren't going to help me? I cut the old crossmember off last night in anticipation.
Sure you did. You get squeamish when using brake cleaner... I would love to be there when you drop the fuel tank....oh wait, did you put your rubber gloves on too?
What tree?
Old March 16th, 2011, 12:34 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Squeamish? He practically called 911 over it. I think he was already drafting his will- so high he was leaving his 90 to Horsey.
Old March 16th, 2011, 01:18 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Interesting...... I'll file that away for a rainy day...... thank you.
What tree?
Old March 16th, 2011, 01:34 PM
bjf's Avatar
bjf
barry f
94 ST #395
I was coughing for weeks. I probably shouldn't have sprayed the brake cleaner in my mouth. You should have seen how nuts I was when I bondod the sills on the 110. I had been obsessed with watching breaking bad so of course I was convinced I had lung cancer.
Old March 16th, 2011, 01:56 PM
Brake cleaner just smells like paint thinner to me. Unless you're welding at the same time and indoors, it's probably not all THAT bad. I've only used it outside though.
Old March 16th, 2011, 01:57 PM
bjf's Avatar
bjf
barry f
94 ST #395
its the way it sprays especially when your mouth is open
Old March 16th, 2011, 01:59 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
You know Brake Clean causes cancer in Cali right? says so on the back of the can.
Helpful tip, if you look on top of the black nozzle(tip) there is an arrow which indicates the direction of the spray. Place the arrow towards the parts to be sprayed(not near your nose either...yeah I know you're a huffer) and you'll be good to go.
What is breaking bad? I don't watch TV... or own one for that fact.
What tree?
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
They usually have an arrow pointing it in the direction of the spray.
Identify this SG 3-Link crossmember! Cube II Defender Technical Discussions 2 May 14th, 2010 04:21 AM
Rear crossmember and Bumper kennybahr Defender Technical Discussions 7 July 18th, 2008 10:57 PM
Rear Crossmember Repair mattarm Defender Technical Discussions 2 June 27th, 2006 07:07 AM
D-90 Rear crossmember neo812 Wanted 2 August 1st, 2004 02:29 PM
