Crossmember Delaminating - Page 3 - Defender Source
Old March 11th, 2011, 12:58 AM
bjf's Avatar
bjf
barry f
94 ST #395
Horsey
Please post the pictures. I am curious what your crossmember looks like following behind those salt trucks. Same shot if you can.
While you are at it take some pics of your brakes.
Seriously I want the crossmember shots
Old March 11th, 2011, 01:19 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Originally Posted by cgalpin View Post
Honestly after replacing two of them now, I think if I ever do it again I'll build one out of tubing too. It would not be hard to make it look the same as a stock one but be vastly superior. The aftermarket replacements are even thinner material than the original and poorly constructed to boot.
I saw thread on one the UK boards where a guy here took a genuine replacement rear xmember and welded it up so it was a sealed box, no holes anywhere that moisture could get inside. As I recall it took him the better part of a day to cut all the pieces and weld them in, but in the end he has a very durable xmember.
Tony
1984 110 "Smokey" (sold)
Old March 11th, 2011, 01:22 AM
california
Geoff M
First things first: move inland where there is no salt, and you can afford a 4 car garage
Maybe Bakersfield?
Old March 11th, 2011, 01:40 AM
bjf's Avatar
bjf
barry f
94 ST #395
Not a bad idea. I assume road crap got tossed up that way and it delaminated. It has been this way since I got the truck. I never thought anything about it but I should have have gone full insane when I put the new skid plate on and put a new crossmember on too. I am good at wasting money and that seems very logical. It is making my truck inferior and that is sad.
Old March 11th, 2011, 10:43 AM
TS888's Avatar
TS888
Tony Sims
1984 110
If it makes you feel any better, your cross member is in better shape than the one I used as a replacement.
Tony
Old March 11th, 2011, 11:53 AM
bjf's Avatar
bjf
barry f
94 ST #395
Why would you do that?
Horsey I want those pics
Old March 11th, 2011, 11:54 AM
I'll stop by the garage either tonight or definitely tomorrow morning. Prepare to be impressed.
Old March 11th, 2011, 02:13 PM
bjf's Avatar
bjf
barry f
94 ST #395
Make sure you get some shots of the rotors too.
Old March 11th, 2011, 02:20 PM
x2 to what Ren Ching said.
Old March 11th, 2011, 02:25 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
[QUOTE=bjf;270704]
What is the process to replace crossmember.
QUOTE]
http://forums.lr4x4.com/index.php?showtopic=27015
Old March 11th, 2011, 02:36 PM
bjf's Avatar
bjf
barry f
94 ST #395
Nice but I wouldnt do the extensions if I went that route. I know what I am going to do.
I am going to live out a commercial for eastwood products
Wire wheel the area
Use this to clean it up
http://www.eastwood.com/ew-pre-paint...osol-11oz.html
Then hit it with this http://www.eastwood.com/ew-fast-etch-32-oz.html
Then hit it with the pre again and finally finish it off with this
http://www.eastwood.com/rust-encapsulator.html
Old March 11th, 2011, 03:18 PM
You are being lazy. The wire wheel won't get into the seam. Must be an LA thing.
Wire wheel the area
Old March 11th, 2011, 03:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
ok so should i stick my thin penis in the seam to rub the rust off?
Old March 11th, 2011, 03:41 PM
Bang it with a hammer and loosen up the rust and get it all out of there with a pick or something.
Old March 11th, 2011, 03:45 PM
It was just a matter of time before someone suggested that.
Only if you want to become known as Needledick the Bugfucker
Old March 11th, 2011, 05:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
I dont have an air hose, can I blow real hard. Have a field day with that
Old March 11th, 2011, 05:46 PM
I'm sure you have something to blow up your inflatable horsey.
You could always use a CO2 setup. Or got to a garage with an air hose.
Bugfucker...
Old March 11th, 2011, 05:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
Could I do whipits at the same time? Wil a co2 bike pump work?
I am not too good with tools so I will ask the same question over and over again. Actually I think when I do it I will skip a huge step like removing old rust. Reminds me of putting new brake pads on and not new rotors.
Old March 11th, 2011, 10:19 PM
does anybody else hear that whining sound?
Old March 11th, 2011, 11:30 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Would highly recommend the POR15. I've used the Eastwood stuff and it's good too but there is really something about the POR15 that makes it different.
Would still go through the step process and even use the Eastwood stuff if you like but finish it with the POR15.
I work with a powdercoater quite a bit and he often does "experiments" with metal stock and different techniques to coat and protect metal. He says the back of the vehicles are the absolutely most corrosive areas. He doesn't think it's just that there is entrapment or poor design. He thinks there is more "free radicals" and other corrosive elements that bias there from flow. No idea. But it seems that these areas are bad on all trucks, G-wagen, FJ62, etc, etc.
BTW......if you're going to f-ck your truck please use protection.......POR your c-ck.
Identify this SG 3-Link crossmember! Cube II Defender Technical Discussions 2 May 14th, 2010 04:21 AM
Rear crossmember and Bumper kennybahr Defender Technical Discussions 7 July 18th, 2008 10:57 PM
Rear Crossmember Repair mattarm Defender Technical Discussions 2 June 27th, 2006 07:07 AM
D-90 Rear crossmember neo812 Wanted 2 August 1st, 2004 02:29 PM
