Cross Seals by rear main - Page 4 - Defender Source
Old September 12th, 2015, 01:42 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
What's the consensus on oil pan gaskets? Have you guys had success using only Right Stuff (sans gasket) or dressing the gasket with right stuff? Which Right stuff?
Also this video shows them using "assembly compound" where the caps mate with the crank but no one mentioned that in this thread. Am I missing something?
Old September 12th, 2015, 02:05 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I use Right stuff every time (no gasket). Works great.
Old September 12th, 2015, 02:25 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Sweet. Thanks for the quick feedback!
Old September 12th, 2015, 05:30 PM
RBBailey
RBBailey
1965 IIa
I smear a small amount on both surfaces, let that get a bit tacky, then a thin bead all the way around to install.
Project:
1965 IIa SWB
Old June 15th, 2016, 05:17 PM
Grover's Avatar
Grover
Question
Originally Posted by Rocketman View Post
Thanks for this post. I am about to start working on a NAS 1993 110 I picked up. First job will e to replace the oil pan gasket while replacing the oil cooler lines (originals).
My two one-man Ferrari shop owner friends swear by Loctite 510/515/518 for sealing surfaces either with or without gaskets. 515 and 518 are used for the tough to seal areas. I have seen the results of a V-12 put together with black rtv, the excess oozed into the inside of the engine, clogging the oil pump pickup and then with the consequences.
I intend to use 518 to lightly coat my cross seals before installing.
Any luck using the loctite 518 product on the cross seals?
seals
Replacing front and rear main seals TND90 Defender Technical Discussions 0 January 24th, 2007 01:10 AM
rear cross member 1of40 Defender Technical Discussions 5 December 1st, 2005 11:48 AM
Rear main seal replacement howellm70 Defender Technical Discussions 4 May 20th, 2004 07:33 AM
