Cross Rod ball joint castle nut thread pitch/diameter? - Defender Source
Old December 5th, 2012, 12:29 PM
Sorry folks -
Part #10 in the diagram below:
http://www.landyzone.co.uk/lz/attach...ng-diagram.jpg
Lost the castle nut for the ball joint last night somehow. I tried 7/16 UNF as well as M12. Both too small. Tried M14 - too large. Does anyone know the thread diameter and pitch of the castle nut?
Old December 5th, 2012, 12:59 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
My best guess is M12 with 1.75 thread
Old December 5th, 2012, 01:01 PM
I'll try my M12 nuts again tonight, Jeff.
Old December 5th, 2012, 01:02 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Do you have aftermarket joints and did you check the diameter of the stud with a caliper? I am pretty sure that all of the joints I have seen are M12. I have a couple spares at home that I can check for you.
------ Follow up post added December 5th, 2012 01:07 PM ------
I just looked back at a previous McMaster order I placed for acorn nuts to help prevent rock rash on the threads and they were M12 with thread pitch of 1.75 (like Jeff said)
Old December 5th, 2012, 01:08 PM
Thanks Jeff - will try again tonight
Old December 5th, 2012, 10:22 PM
I must have some kind of non standard ball joints because the threads are m12 but 1.75 is too coarse. Is it possible to have ball joints with m12x1.0 or m12x.75??
Old December 5th, 2012, 10:34 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
without doing any legwork, this site has been super helpful
http://lrparts.net.ru/
it might offer a few different specs for the nuts...
Old December 14th, 2012, 07:44 PM
The many joys of defender ownership...here are four of them.
From left to right: m12x1.0 1.25 1.50 and 1.75.
And the winner is.... 1.50!!!! (Correction, it is 1.50!!!)
Now to buy the castle nut. What a pain!!
Old December 14th, 2012, 07:46 PM
And the winner is.... 1.25!!!!
Some of the come with nyloc now if you can't find a castle.
Old December 14th, 2012, 07:48 PM
Yes, I think you are right! As you can see the ball joint has no hole for a cotter pin. Now I know why I "lost" the castle nut...there probably wasn't one there to begin with!
Old December 14th, 2012, 08:31 PM
I do that. A lot ...
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
WTB: D-90 Cross rod end, steering drop arm, ball joint kit Blakesrover Wanted 1 October 1st, 2009 09:40 AM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
size of castle nut holding ball joint on rear upper triangle Noah Defender Technical Discussions 2 January 3rd, 2007 08:23 PM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
