Cross drilled rotors - Defender Source
Old September 3rd, 2004, 05:07 PM
Milo's Avatar
Milo
chris glynn
95 yellow D90
I put on cross drilled rotors and they make a wierd bearing sound when driving and grind when I hit the brakes hard. Anyone have this prob? Thanks
Old September 3rd, 2004, 10:02 PM
When the air moves across the cross drilled rotor it will sound kinda like a bad bearing, I have seen this before. What exactly do you mean by grind? like metal on metal or like when there is dirt in the breaks?
Old September 4th, 2004, 03:43 AM
Milo's Avatar
Milo
chris glynn
95 yellow D90
Well it sounds like metal to metal and I took it by the shop and the tech thought it was weird but said that everything seems o.k and I'll run through pads fast
Old September 4th, 2004, 11:24 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
I've done several cross drilled rotors install and most did the same thing at first, and after 100 miles it went away. No idea why it's doing though.
World traveler
Old September 4th, 2004, 01:01 PM
Milo's Avatar
Milo
chris glynn
95 yellow D90
Could it be the brake pads? I think they put on Mintex
Slotted and drilled Brake Rotors mdmccallum Defender Technical Discussions 1 July 31st, 2006 12:00 PM
Rf Rack install ? front cross bar placement paulb Defender Technical Discussions 0 June 12th, 2005 03:52 PM
Brembo Rotors on eBay Glenn_Guinto Defender Technical Discussions 15 March 29th, 2005 05:11 PM
New Safari Gard 3-link cross member Davis For Sale - Parts 2 July 4th, 2004 05:00 AM
Are Michelin Cross Terrains Evil? JimC Defender Technical Discussions 8 January 23rd, 2004 06:27 PM
