Crazy Rattling Noise From Exhaust/Underneath - Defender Source
Old January 25th, 2008, 05:49 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
First I will tell you that it has been colder than a witches tit here the past week so I have not had a chance to crawl under Grover to try and pinpoint this noise. All of a sudden last week I started getting a rattling noise from underneath, in the area directly under the passengers, more on the right side. It does not do it when the vehicle is cold, only once it has warmed up. It won't make the noise at idle. The only time it makes this kinda hollow rattling noise is when I accellerate, say between 1500 and 2500 rpm (est). It almost sounds something like a piece of metal tapping on the exhaust. It will make this noise while in neutral, so no tranny or tcase issues. I would think if it was a stuck valve or lifter it would make the noise when cold and go away after warming up...
With this vague description, does anyone have any ideas?
Semper Fi!
Old January 25th, 2008, 07:09 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Time for some new cats. Honycomb breaking up inside the catalytic (sp?) converter. Fix it before it clogs up solid makes the exhaust redder than hot and burns the truck to the ground.
or it could just be something metal banging against the exhaust
Matt Browne
Old January 25th, 2008, 09:39 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
2nd that, it's the cats alright, been there done that. Easy fix though that any old muffler shop can do. If you want some good sound, consider going ahead and doing a Flowmaster muffler while they are under there. I have 40 series and love it. It has a nice growl, but not obnoxious.
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old January 25th, 2008, 11:27 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Cats. I replaced mine about 3 months ago. Flowmaster universal cats, got off amazon for about $60/each and had my muffler shop install them. Oddly, amazon was the cheapest place I could find anywhere, including shipping...
Old January 25th, 2008, 01:04 PM
Wolf Fabrication
Sterling Archer
'08 D3
Wow, thanks guys! I already have a new NRP muffler and exhaust. I will replace the cats with some Flowmasters. I am glad it should just be something simple like the cats.....
Any idea what the part number was?
Did you mean Magnaflow Universal Cats #94004?
Semper Fi!
Old January 25th, 2008, 08:08 PM
I was thinking about those Magnaflows since I already have a muffler and I like it. If I hit the muffler I can hear something in there i think it parts of my cats. Could any increase in power/economy be expected from those magnaflow cats??
Old January 26th, 2008, 02:51 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yeah, I was thinking of those magnaflows...thanks!
Old February 9th, 2008, 06:23 PM
Wolf Fabrication
Sterling Archer
'08 D3
Just as a follow-up, I replaced both Cats with some Magnaflows and the noise is gone!
Semper Fi!
Old February 9th, 2008, 06:50 PM
do you have part numbers for the Magnaflow cats? What muffler do you have?
Old February 9th, 2008, 09:26 PM
Wolf Fabrication
Sterling Archer
'08 D3
Magnaflow Universal Cats #94004. However, I would do some research to find ones that are 2" ID versus 2"OD. It would have been so much easier to slip them on and weld them versus butt-welding them.
I am running NRP exhaust.
Semper Fi!
Old February 10th, 2008, 11:39 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Get a 2" ID sleeve--makes life easy. Or just cut two 3" pieces of 2" ID tubing.
Old February 10th, 2008, 11:57 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Is your tubing into and out of the cats offset on one side (I think its the passenger side)? If so how did your muffler shop get around this b/c my shop says that they need to redo the whole system? I think they are screwing with me?
Did yo also replace your O2 sensors?
Old February 10th, 2008, 04:03 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, crappy auto parts places were out.
My passenger side did have an offset cat, meaning the exhaust entered towards the top (when viewed from the side) and existed towards the bottom. That should not make any difference when installing a cat with centered entrance and exits. I welded my own, but any reputable muffler should should be able to make them work.
I did not replace the O2 sensors, but should have.
Semper Fi!
Old February 10th, 2008, 06:09 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I did not replace my O2 sensors. Probably should, but at the same time, I have no indicator that they are going bad. Question is if the Cats went bad due to the O2 sensors or if they just wore out--just don't know. Does anyone have a check for this? I have no codes thrown...
Old April 6th, 2009, 07:12 PM
I can hear the DS cat rattling around. I have a code 44. I hope to get it replaced this week.
exhaust
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
lifted d 90 noise 4x4x46 Defender Technical Discussions 11 June 15th, 2005 07:29 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
