Crankshaft timing gear removal - Defender Source
Old January 28th, 2012, 08:42 PM
I had the pleasure of removing my seized timing gear from the crankshaft today on my 300 tdi. I have the timing belt tool kit, but it did not include a crankshaft gear puller. I figured I post up how I did it in case anyone else runs into this issue.
The timing gear has 3 5mm bolt holes in it to attach a puller. If yours is seized you need to find some long 5mm bolts that are hardened. I had no such luck. I went to the dealership where I work to see if we had the puller, which we didn't. After running around looking for bolts I decided to take a different route. I ended up drilling out and tapping the 5mm holes to accept a .25" bolt that was part of a puller set I already had. Once I did this it came right off!
It is also worth noting that I had extra room to work with because of the 300tdi/lt77 combo.
ID:	46742   Click image for larger version
ID:	46744   Click image for larger version
ID:	46746   Click image for larger version
Old January 28th, 2012, 09:19 PM
Are you doing the entire timing belt, timing cover seals, etc I'd assume?
Old January 29th, 2012, 01:00 AM
I'm doing the belt, three pulleys, and the cover gasket. I didnt order new crank seals, but they weren't leaking, so I'm not too concerned.
I'm going to reseal my vacuum pump too, if it will clear the inner fender.
Old January 29th, 2012, 09:36 AM
Naplm00
Matthew
Mine was siezed on too. I used my clutch puller from a puch moped. Its cheap and works perfectly with a heavy washer. Also works for the steering wheel.
http://www.treatland.tv/puch-clutch-...puller-e50.htm
Old January 29th, 2012, 07:52 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Jimmy, you get everything done? Running?
Land Rover 110
Old January 29th, 2012, 08:34 PM
I did finally! I had trouble getting the belt on because I forgot to slacken the bolts on the injection pump, but that's what I get for not looking at the manual... Thanks again for letting me borrow the tool kit! I'll get in touch with you about returning it this weekend.
crankshaft
Crankshaft Pulley Removal Smirk1010 Defender Technical Discussions 1 October 13th, 2011 02:30 PM
In situ gear selector housing removal michael67 Defender Technical Discussions 4 September 25th, 2011 12:34 AM
300tdi crankshaft gear D90user Defender Technical Discussions 0 October 19th, 2010 01:07 AM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Speedo Gear Removal 48vphantom Defender Technical Discussions 2 March 27th, 2005 02:51 AM
