Crankshaft Pulley Removal - Defender Source
Old October 9th, 2011, 11:16 AM
Smirk1010
Justin
1986 3.5 V8 Ninety
I am trying to swap out the crankshaft pulleys on a 3.5 V8. I have the pulley/dampener assembly pulled but I can not separate the pulley from the dampener. From all the diagrams I have seen these should be separate parts. I have tryed tapping a wedge between them, but they wont budge. I notice that there is a pin that passes through the assembly adjacent to one of the bolt holes. Does this need to be drilled out to remove the pulley? Thanks again for any help guys.
Justin
ID:	42581   Click image for larger version
Old October 13th, 2011, 02:30 PM
Smirk1010
Justin
1986 3.5 V8 Ninety
So the answer is, yes. They come apart, no drilling was required. Four wedges and a good amount of whacking is all that was needed. Answer courtesy of Loco George.
crankshaft, pulley
TDI crankshaft pulley locking tool Michael Wanted 0 July 27th, 2011 08:34 AM
Looking for oil pump / front cover & crankshaft pulley HeloBubba Wanted 1 February 12th, 2011 02:20 PM
Crankshaft pulley bolt size CDNRover Defender Technical Discussions 2 April 18th, 2008 11:06 PM
crankshaft pulley Puller bstraw Defender Technical Discussions 1 July 2nd, 2007 02:57 PM
Crankshaft Pulley bolt removal kellymoe Defender Technical Discussions 16 November 1st, 2006 03:29 PM
