crankshaft pulley Puller - Defender Source
Old June 29th, 2007, 01:30 PM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
What type of puller works best for the 3.9, while the engine is in the truck? jaw type or bolt type?
Old July 2nd, 2007, 02:57 PM
dkjbama
Derek Johnson
'97 D90ST - Lil' Mule
You shouldn't need one. Just remove the big bolt in the center of the pulley and it should slide right off. You may need an impact wrench to break the bolt loose though. I believe the torque spec on that bolt is about 300 ft-lbs.
Lil' Mule - 1997 D90 ST Monza Red #1254
crankshaft, pulley
300 tdi crankshaft pulley pendy For Sale - Parts 0 February 3rd, 2009 09:13 PM
Crankshaft pulley bolt size CDNRover Defender Technical Discussions 2 April 18th, 2008 11:06 PM
Crankshaft Pulley bolt removal kellymoe Defender Technical Discussions 16 November 1st, 2006 03:29 PM
Crankshaft Pulley/dampner Davis Wanted 2 June 28th, 2005 12:12 AM
Replacing pulley bearing Campbell Defender Technical Discussions 4 April 26th, 2004 08:42 AM
» Defender Registry
Red
KGH
Nikki
TaylorGarner88
Add your Defender
