Crankshaft pulley # - Defender Source
Old June 3rd, 2015, 08:31 AM
tim
Timothy Homewood
Defender 50th going topless
Crankshaft pulley #
Hi, appears the crankshaft pulley is worn out on my Defender50th (1998) '4.0' basically the same as the NAS 97.. Is the pulley part number lhg000060 as per the Discovery11 and Range Rover of similar years.
Cheers, tim
Old June 3rd, 2015, 09:51 AM
jafir's Avatar
jafir
Jafir Elkurd
The 1997 NAS was err4922 and that has been superseded to err7373 and that has been superseded to NLA. (at least from the dealer).
------ Follow up post added June 3rd, 2015 08:54 AM ------
The part number you've listed is for D2/P38 (even the GEMs P38 it seems). I don't know if it will work or not. Assuming it lines up, I'd think it would.
Old June 3rd, 2015, 11:08 AM
tim
Timothy Homewood
Hi, thanks, it seems that the 98 V8s had a metal rubber metal 'damper' construction so may be the same as the D2. Is the 1997 a solid pulley?
Thanks, Tim
Old June 3rd, 2015, 12:18 PM
what part is worn out? if it is just the sealing surface that can be fixed with a speedi-sleeve.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 4th, 2015, 11:12 AM
tim
Timothy Homewood
The rubber inner ring has perished and cracked..so the metal inner and outer metals are unstable. It appears this one assembly at one shocking price.
Tim
Old June 4th, 2015, 11:29 AM
Looks like a disco 1 pulley is the same part number as the one posted- err7373
The LHG000060 from the D2 and Pr38 rangie looks shallower. See photos...
These are from ebay maybe you can find one there. Or in a junker...
ID:	122217   Click image for larger version
Present:
1987 RRC- "Chewy 2"
Past:
Old June 5th, 2015, 10:39 AM
tim
Timothy Homewood
Thanks for the images, and given the radiator was out, gave it a reasonable look dispite the condenser in the way. Certainly looks like one of these, question is now, which one?
Cheers, tim
crankshaft, pulley
300 tdi crankshaft pulley pendy For Sale - Parts 0 February 3rd, 2009 09:13 PM
Crankshaft pulley bolt size CDNRover Defender Technical Discussions 2 April 18th, 2008 11:06 PM
crankshaft pulley Puller bstraw Defender Technical Discussions 1 July 2nd, 2007 02:57 PM
Crankshaft Pulley bolt removal kellymoe Defender Technical Discussions 16 November 1st, 2006 03:29 PM
Crankshaft Pulley/dampner Davis Wanted 2 June 28th, 2005 12:12 AM
