Crankshaft Pilot Bearing Question - Defender Source
Old May 8th, 2007, 11:58 PM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
Question Crankshaft Pilot Bearing Question
I installed a new clutch, rear main seal, and pilot bushing in the crank. Had flywheel resurfaced... etc.
After driving for about 200 miles I noticed a weird noise coming from inside the bell housing.
I though damn... my clutch must be bad... something?
So I took it apart and it turns out everything is alright with one exception:
The pilot bearing that was in the crank just slipped out. The sides of it are scored a little bit.
The inside of the crank is worn down a bit where the bushing was turning inside.
I guess this was making the noise... when the bushing was binding, turning or both.
I don't know what the heck to do right now, and I don't know how this happened!?!
What should I do?
Thanks in advance for any suggestions.
Oh my engine is a 4.6 from RPI.
Well at least the rear main is not leaking anymore :-)
Name:	crank shaft bearing.jpg
Old May 9th, 2007, 01:39 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Get a new pilot bushing and see how tight it fits into the crank. If it is a tight fit, install it and put the truck back together. If the new one just slips in you may have worn the pilot hole in the crank (doubtful). 549911 is the part number
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old May 9th, 2007, 02:56 AM
4x4sche
john
73 SIII_ 97 D90_94 Disco
Get a new one in and glue it to the flywheel with blue loctite. Common problem.
Old May 9th, 2007, 05:31 AM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Did you even bother to grease the inside of the pilot bush before you put it back in?
Robert Deniro
Old May 9th, 2007, 06:45 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The current batch of pilot bushings are not made correctly. Land Rover knows of the problem, but because it can be easily cured they did not recall the parts. They are too tight on the gearbox side. We have seen this over the last 6 months or so. We have to machine them so that they are the right size. You can also do this with some sandpaper if needed to get the I.D. correct.
Its a problem with the bearing, not your engine.
Email:
Old May 9th, 2007, 08:27 AM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
Wow... Thank you all for the quick responses!
Yes I did put a tiny bit of grease on inside, but not too much that it would dislodge the bearing.
I mean, just a little bit of synth grease to get the input shaft through smoothly.
I probably should have used some special grease, but I used red grease which is synthetic.
The inside of the crank is a little worn, but I had another bearing that I popped out of an old 3.9L which had 100k miles on it, it looked good. It is pretty snug on the end of the crank, I would have to hammer it in.
Maybe I should have someone just machine one for me like .001 over? I don't know how to measure the inside. What material is it? Is it brass?
The bushing actually came from British Atlantic; I don't know if it was Britpart or Genuine... Can't remember. I guess if the old one from the 3.9 is good I can use it. And I know the input shaft fit nicely for a long time on that one!
How can I tell if my crank is screwed up? I am worried about it being out of round in the center. I guess I could have it machined larger and just make a bigger bushing to fit. But this would require me taking the engine out. I will take a picture of the inside of the crank. You can see clearly where the bushing had damaged the inside of the crank. Be right back with that photo.
Here are some photos...
You can easily feel the rut where the old bearing was.
It bored out the hole :-(
I am so pissed... I should have been warned about this by the vendor.
If the hole is perfectly round, then it should not effect performance if the new bushing fits tight right?
Please tell me I don't have to get this machined :-(
But do tell me... well you know what I mean.
Thanks again,
Heath
One more thing...
Could I have a bushing machined that is a tad bit longer... to get more grip?
Just another thought...
What if the input shaft from the trans is not spinning straight?
Could that have caused this?
I can check it with a dial indicator to make sure it spins straight. Will that work?
Is this even a problem...
Damn, I'm thinking too much now.
Name:	crank shaft2.jpg
ID:	9270   Click image for larger version
Name:	crank shaft1.jpg
Name:	crank shaft3.jpg
Old May 9th, 2007, 01:32 PM
Neil McCauley
Neil McCauley
Well technically the mainshaft only has to spin inside the bushing as the bushing dosen't move itself, so mabye glueing or epoxy the bush into the crank will work while greasing the mainshaft. I don't see what could happen.
Robert Deniro
Old May 9th, 2007, 03:23 PM
Roadsiderob
Robert Dassler
1994 D90
I doubt your crank is damaged. All 3 of the cranks I have here have the lip inside...it keeps the bushing from going too deep. I doubt you could damage a steel crank with a brass bushing if you wanted to. I would measure the ID of a new bushing after installation and use a bit of emery cloth to open it up if it's too tight. I tried all 3 pilot bushings I have on the shelf and all are a slip fit on a gearbox input shaft. I don't know if the fit would tighten up once the bushing is installed in the crankshaft. These could also be correct bushings as they've been on the shelf for a while.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old May 9th, 2007, 03:51 PM
ECR's Avatar
ECR
The problem is once it is installed in the crank. Emery cloth and a little elbow grease will cure the issue though. People don't see the issue when they use a universal clutch line up tool (unitl they have to wrestle with getting the engine and gearbox to mate), but like Rob has in hand, we use cut off input shaft as our line up tool so it shows the issue. We have had to modify the last 8 or 9 we have done.
Email:
Old May 9th, 2007, 07:03 PM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
So true.
Even though the bushing slipped easily over the input shaft while it was out...
I didn't think of the fact that it compresses the id once it is in there!
I did use a universal alignment tool.
It was a bitch to get the trans input shaft and the engine to mate!
I appreciate your help guys...
I think I should be good now!
Time to crack open a brew.
-Heath
Old October 4th, 2009, 08:31 AM
I'm having pilot bushing issues now too. The bushing was an extremely tight fit into the crank shaft and I had to tap at it with a rubber mallet. Then, when I tried to mate the trans, the input shaft broke pieces off the bushing. Now I have a crumbling bushing that I need to remove. I've never had one be this difficult before. What a PITA.
Old October 10th, 2009, 03:41 PM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
Jim,
I'm pretty sure I remember the busing being defective from the manufacturer. The ID was to small. They said to just sand down the inside, but I ended up using a genuine one from the 3.9.
My startup iSpeech.org, a
SaaS company.
Old October 13th, 2009, 03:29 PM
A follow up - the ID of my bushing seemed to be fine, but I had excessive interference between the hole in the crank and the bushing. I wrapped a large drill bit in tape and stuck the bushing over it - that allowed me to evenly sand the bushing down and to round off the front edge a bit to assist installation. I still had to put the bushing in the freezer to get it to slide in.
I removed the damaged bushing using a 19mm A-arm bolt and grease. Two whacks on the bolt with a rubber mallet and hydraulic pressure popped the old bushing out.
After much unnecessary fiddling, the trans bolted up all nice.
Name:	DSCF4484 - Resized.jpg
Old October 13th, 2009, 03:45 PM
JimC I see you are picking up some of my "hack" methods.
Good work!
Old October 13th, 2009, 03:47 PM
Neil McCauley
Neil McCauley
Kinda surprised that worked. I just cut up the old one with a chisel, the new one pressed in with some grease, a socket and a hammer. I keep hoping mine dosen't spin around in the crank like what happened to Hans.
Robert Deniro
Old October 13th, 2009, 03:57 PM
I was more concerned that the whole scene had the appearance of a bronze alien parasite bursting out of the iron chest of the flywheel.
crankshaft
300tdi pilot bearing Ren Ching Defender Technical Discussions 3 May 28th, 2008 05:39 PM
R380 Transmission Input Shaft Bearing Question Heath Defender Technical Discussions 0 March 15th, 2007 03:09 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
