Cranked rear radius arms - Defender Source
Old July 14th, 2015, 01:54 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Anybody care to share their experiences with cranked rear radius arms? Needing to do my bushings, and looking at what else may need to be done. Running a 2" OME lift. The whole "correct geometry" makes sense to me, probably staying with rubber bushings as a majority of my driving is on road. Not sure if there would be much need to go to poly, or is there???
Let's hear it....
Old July 14th, 2015, 02:20 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Three advantages.
1. Less bushing bind with lift
2. Stronger than factory if impacted by rock etc
3. Allows for correct pinion angle with lift (via spacers) or arm length specific for lift and type of rover.
I have always run rovertym with factory rubber bushes with good results.
Old July 14th, 2015, 02:29 AM
Landy_Andy's Avatar
Landy_Andy
Andy
As above & OEM bushings can give better vibe isolation than harder Poly.
Old July 14th, 2015, 02:45 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Andy, what are you running on the Truggy? That's one REALLY cool build!
Old July 14th, 2015, 06:46 AM
both of my vehicles benefitted from "cranked" rear links, I am running Rovertracks,
Old July 14th, 2015, 07:17 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Roverdoc View Post
Three advantages. 1. Less bushing bind with lift 2. Stronger than factory if impacted by rock etc 3. Allows for correct pinion angle with lift (via spacers) or arm length specific for lift and type of rover. I have always run rovertym with factory rubber bushes with good results.
nailed it.
Old July 14th, 2015, 08:25 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Be careful what rubber bushings you go with. Unless its Genuine quality or equivalent I'd go Poly all the way. The lower end rubber bushings are garbage and don't last at all.
And you've got nothing to lose with cranked rear arms.
Old July 14th, 2015, 09:07 AM
I would suggest the Rovertym cranked rear arms.
Cost is on par with competitors (in some cases cheaper) and their design is immensely strong. Probably overkill, but if you're going to pay money...
Old July 14th, 2015, 09:15 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Agreed, Genuine bushings or bust. RTE's arms are definitely overkill but super nice.
http://www.rte-fab.com/products?page...category_id=10
I haven't started running them yet, but I bought a set of our own to try out. I can do these for $149
PROLINE REAR CRANKED TRAILING LINK SET, RNA5610, TF509, RNA509 - Rovers North - Classic Land Rover Parts
Old July 14th, 2015, 09:43 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
I just put a set of these on my 90, was having issues getting the bushings out of the old arms, so for the cost of the labor and new bushings, figure I will pick the cranked arms. They have a great fit and finish for the $$.
~ Semper Fidelis ~
Old July 14th, 2015, 09:55 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Glad to hear they worked out for you Adam!
Old July 14th, 2015, 12:22 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Rovertym's do look pretty nice. The Proline from RN look the same as the Terrafirma.
Can't find anything out there on Rovertriacks though. Tried looking him up, the site is no longer (obviously due to the whole "Rover" law suit. (oops, can I get sued for saying "Rover" LOL.)
For rubber, I would definitely go Genuine. Cheap aftermarket is just that...cheap.
Old July 14th, 2015, 12:23 PM
Rovertracks is long gone, unfortunately. He made some innovative products.
Old July 14th, 2015, 12:50 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I had the RoverTracks rear arms. Paint the Proline black and you couldn't tell the difference.
Old July 14th, 2015, 01:23 PM
just went on my short list Z
Mark Kellgren
KM4BOR
Old July 14th, 2015, 01:29 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
~ Semper Fidelis ~
Old July 14th, 2015, 01:38 PM
bish1865
Bruce Bishop
1985 Defender 110
I went with Scorpian Racing trailing arms and blue poly bushings with great results. I replaced all my bushings when I bought the truck with factory OEM and only got 3 years out of them. I've had the poly three years and the truck drives beautifully and rides better than the Wife's G-500. So my vote would be blue poly bushings.
Old July 14th, 2015, 01:43 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Rear 4 link uses Currie Johnny joints, front 3 link uses 'Polybush' brand red radius arm bushes.
Thanks for the props !
Old July 14th, 2015, 03:17 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Interesting, TF509 is the Terafirma part number. Are these just the Terafirma parts with grey paint?
Old July 14th, 2015, 03:20 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
No, they're different parts. TF509 is just in the description for associated parts
Castor corrected bushings vs. cranked radius arms RiftRover Defender Technical Discussions 17 April 17th, 2015 11:23 AM
WTB Cranked Front Radius Arms grnrvrs Wanted 2 June 24th, 2013 05:07 PM
cranked RTE radius arms cdb For Sale - Parts 11 July 9th, 2012 11:06 PM
OME 764 springs = cranked radius arms? cabell Defender Technical Discussions 2 August 17th, 2010 11:43 PM
Bolt size for Radius Arms and Rear trailing arms Rugbier Defender Technical Discussions 5 May 29th, 2009 10:23 AM
