Crank shaft Seal - Defender Source
Old May 18th, 2011, 07:02 PM
Zooben1
Ben Williamson
1983, 110 Miss Scarlett
Crank shaft Seal
So i am trying to replace the cranks shaft seal (front oil seal) and i can not get it to break lose.
I have put it in gear and spun and spun but it seems not to lock. (wheels keep rocking)
I have also tried to put a pry bar in the CV joint to stop the turning no luck.
I am trying to use a pipe wrench to turn the bolt.
EDIT: Sorry its a 4cyc 2.25 petrol
Any advice?
Thanks in advance,
Ben
Old May 18th, 2011, 07:29 PM
dchapman
Daniel Chapman
1999 D1
Manual transmission? Block the wheels and put it in gear.
Old May 18th, 2011, 09:44 PM
Zooben1
Ben Williamson
wheels are on the ground and in gear and the bolt just wants to wobble and spin back like it has a spring in it??
Old May 18th, 2011, 09:56 PM
There are two "normal" methods.
1) Large impact gun.
2) Put long bar on bolt. Rotate until it touches the chassis. Bump the starter (make sure coil is disconnected so it won't start).
Tom Wood Custom Drive Shaft: My story. :) Roving Beetle Misc. Chit-Chat 5 April 21st, 2012 01:37 PM
200tdi rear crank seal D90user Defender Technical Discussions 3 March 23rd, 2011 02:50 PM
need 300 tdi timing belt crank shaft pulley andyrad Wanted 0 July 24th, 2010 02:11 PM
Rear Main Shaft Seal, how far back to drift in? Neil McCauley Defender Technical Discussions 4 September 12th, 2009 01:28 PM
Crank shaft pulley Mike Hippert Defender Technical Discussions 13 April 3rd, 2005 01:13 AM
