Crank shaft repair sleeve - Defender Source
Old June 22nd, 2011, 06:50 PM
Zooben1
Ben Williamson
1983, 110 Miss Scarlett
Ok, so I keep biting off more and more.
I have taken off the crank shaft pulley in hopes of replacing the crank shaft seal. After a long fight and a 41mm socket and a 6ft breaker bar the crank shaft seal is ready for replacement. Only to find that the crank shaft pulley has a ring worn into it.
Any ideas on where to get a Speedi sleeve or crank shaft repair sleeve for the 2.25 petrol? or other suggestions?
Ben
Old June 23rd, 2011, 09:34 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Measure the crank with a mic. I think McMaster Carr has sleeves, possibly Summit Racing too. If those fail, google speedi sleeve and I'm sure you'll find a vendor.
Tony
1984 110 "Smokey" (sold)
Tom Wood Custom Drive Shaft: My story. :) Roving Beetle Misc. Chit-Chat 5 April 21st, 2012 01:37 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
Crank shaft pulley Mike Hippert Defender Technical Discussions 13 April 3rd, 2005 01:13 AM
Why not remove the inner bushing sleeve? ezzzzzzz Defender Technical Discussions 0 June 10th, 2004 07:00 PM
