Crank shaft gear puller 200tdi - Defender Source
Old March 3rd, 2014, 12:02 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Has anyone made their own crank shaft gear puller for a 200 tdi ( or know of a universal one that will work it is a 3 bolt and has to have 5mm long bolts to do it properly)
Chris "V"
Old March 3rd, 2014, 12:39 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
I had to barrow one and did some damage to it. I am still looking for a replacement to make it right.
Old March 3rd, 2014, 02:42 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If you're asking about the crankshaft timing gear, have removed many without an issue.
Generally they come off with a lever used against a block of wood.
RDavisinVA
Old March 3rd, 2014, 03:16 PM
You can buy the Rover timing kit with the puller quite cheaply. But I agree, I have not needed one. They always pull off by hand.
Old March 3rd, 2014, 04:18 PM
Chris Velardi
Chris Velardi
1975 101FC
Even with the key way you just pried it off with a flat blade and a block of wood ? who has the Rover timing kit cheap ?
Chris "V"
Old March 3rd, 2014, 04:37 PM
Look on eBay or most of the Rover suppliers. Around $50.
Old March 3rd, 2014, 05:54 PM
Mine was pretty seized on there, I tried prying a lot before going to work to get the puller.
http://www.defendersource.com/forum/...ad.php?t=35406
Old March 3rd, 2014, 07:21 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
OK just checked the link...
For me, the Wood block and lever has always worked like 10 men, but when it doesn't, will use the timing kit extractor...
Just checked, it's in our timing kit.
RDavisinVA
Old March 3rd, 2014, 07:50 PM
Chris Velardi
Chris Velardi
1975 101FC
I'll try the block and lever tomorrow. it appears the 300tdi uses two M6 bolts, I'm pretty sure the 20tdi uses 3 m5 bolts. I'll verify again tomorrow
Chris "V"
Old March 3rd, 2014, 08:00 PM
solarguy's Avatar
solarguy
Abraham Bell
Robert are you selling a timing kit?
Old March 3rd, 2014, 08:07 PM
Chris Velardi
Chris Velardi
1975 101FC
Robert link ?
Chris "V"
Old March 4th, 2014, 04:00 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi chaps,
ebay:http://www.ebay.co.uk/itm/PULLER-for...item53eb86b98c
regards
Gren
Old March 4th, 2014, 04:05 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
No, but did check the one in the shop. Planning to get your pick-n-shovel ready this week, though.
RDavisinVA
Old March 4th, 2014, 04:27 PM
I meant like this one: http://www.ebay.co.uk/itm/449845-15P...item43bb315012
All the tools.
200tdi, tdi
200tdi...balance shaft? sonoronos Defender Technical Discussions 4 November 14th, 2011 08:58 PM
Crank shaft repair sleeve Zooben1 Defender Technical Discussions 1 June 23rd, 2011 09:34 AM
Removing crank gear 300tdi D90user Defender Technical Discussions 6 November 2nd, 2010 12:09 AM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
Crank shaft pulley Mike Hippert Defender Technical Discussions 13 April 3rd, 2005 01:13 AM
