Crane Cams--are they available? - Defender Source
Old June 5th, 2004, 10:47 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Question Crane Cams--are they available?
I am trying to find info on Crane Cams for the Rover V8. I have checked their site and a bunch of places, but can't find any part numbers/info. Do any of you run one and if so, do you have a part number or even a cost estimate? Thanks!
Old June 5th, 2004, 12:45 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
You can buy them from Mike Green at www.offroadexperience.com. He's done a lot of Rover v8 performance work.
Tell him I sent you!
DW
Old June 5th, 2004, 08:59 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Chris,
Summit Racing has Crane Cams for Rover V8's...along with performance lifters and roller timing sets. You won't find it in the catalog...you'll have to call them. I think I paid $150-200 for the cam and less than $100 for lifters and about $70 for a roller timing set. We used cam part number 900531, which is a mild RV cam and put it into a 4.6L for my Brother in laws 94 Range Rover. We are very pleased with the performance.
Cheers,
Rob Dassler
Old June 6th, 2004, 11:42 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Doug and Rob, Thanks--it helps alot.
Old June 6th, 2004, 01:14 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Rob which cam would you recomend for a 3.9?
Old June 6th, 2004, 01:42 PM
Roadsiderob
Robert Dassler
1994 D90
Yousef,
I would probably pick the 900531 based on my positive experience with it. I think it is the mildest grind that Crane makes for the Rover V8. If you call Summit racing, they can give you a better idea of how the cams they offer will perform...such as power and torque curves. I chose the 900531 because the power and torque peaks were not too far up the RPM range...the car rarely sees 4000 plus rpm, and smooth low rpm power and torque is what is needed for off roading. I didn't want a lumpy race car idle or a power band I couldn't use. Summit Racing has a nice web site and the phone number is available there. They have always had what I wanted in stock.
Cheers,
Rob Dassler
P.S. Next time you're at Denver South, Say hello to Linda for me.
Old June 6th, 2004, 08:48 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Robert,
Is it nesescary (spelling?) to also do the lifters and rollers when you do the new cam? I am assuming that as long as your in there you might as well do it. Am I right?
Old June 6th, 2004, 11:52 PM
Roadsiderob
Robert Dassler
1994 D90
Kevin,
As the cam and lifters wear together, you must replace the lifters...as for the timing chain, you need to inspect it for wear and stretch and replace it if necessary...I personally would not do the job without replacing it as it is cheap insurance and if the cam is worn enough to warrant replacement, the chain will be too.
Rob
Old June 7th, 2004, 01:17 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
Rob,
Thanks, I am planning on installing a edelbrock intake manifold and 4 barrel carb sometime this summer and as long as I have it apart I might as well change the cam. Summit seems to have a good selection for rovers, you just need to ask. There prices are not that bad either.
Kevin
Old June 7th, 2004, 07:17 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Thanks for the help--I ordered the cam and lifters today. Crane Cam #900531 and Lifters #99284-16 for those that are looking for a distributor drive cam with a high torque/low rpm V8 profile. Basically $145cam/$80 lifters from Summit Racing.
Defender won't Start DJ Menasco Defender Technical Discussions 21 January 29th, 2007 11:04 AM
Cams, lifters, timing chains vesparover For Sale - Parts 11 March 10th, 2006 11:20 PM
RPI cam or Crane pro's & cons Bowtracer Defender Technical Discussions 1 March 4th, 2005 05:00 PM
Camshaft change 3.9 V8 95 D90 Neo Defender Technical Discussions 2 December 12th, 2003 02:29 AM
