Cracked y-pipe - Defender Source
Old June 8th, 2005, 11:43 PM
Cracked y-pipe
I spent some time tightening all the manifold bolts and the bolts connecting the manifolds to the y-pipe. At that point I could tell that I have a crack on the drivers side downpipe at the bend right below where it meets the manifold.
I seem to recall someone saying that a weld wouldn't hold. Is this true? Maybe weld a gusset to hold it?
charles
Old June 9th, 2005, 12:26 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Just a plain weld probably wouldn't hold, but if you gusset it or sleeve it somehow, that should make enough of a difference.
Considering the cost of a new Y-pipe, there's no reason NOT to at least try.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 9th, 2005, 12:28 AM
You've got that right! Hell, I could buy a nice welder for the cost of a new y-pipe.
charles
Old June 9th, 2005, 12:57 AM
Hans's Avatar
Hans
Hans Haase
Yep, don't I know it! Once I get back from vacation, I have to replace my whole exhaust :-(
-Hans
My oil line fix
Old June 9th, 2005, 01:09 AM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I have a good shop here in LA that welded my Y in exactly that place, and it held for months and never failed, before I went to a larger diameter pipe and replaced it. I think it's fine if you have a quality independent do the welding....
DW
Old June 9th, 2005, 11:19 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
The Y-pipe is Stainless steel so you'll have to have it TIG welded - lot easier to do properly if the pipe is off the truck.
Old June 9th, 2005, 11:25 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Charles, EuroSport in Lorton has successfully welded Brian's manifold, you might want to call them.
Tony
Old June 9th, 2005, 02:09 PM
Hans's Avatar
Hans
Hans Haase
Wait..... you're saying that the factory Y-pipe is already stainless? I'd assumed it was regular steel like the tailpipe and muffler that has already rusted to pieces on mine.
Hmmmmmmm......THAT could save me a few bucks if I can find a shop willing/able to just replace the cats for me.
-Hans
My oil line fix
Old June 9th, 2005, 02:41 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I Mig weld stainless all the time, just use the right wire. FYI
Old June 9th, 2005, 03:31 PM
Thansk for the tips guys. I'm going to get an estimate from a local shop - see if anyone local with a welder is crazy enough to help me do this, and go from there.
Tony, I'll give EuroSport a call - not sure I have the time to go down there to get an estimate.
charles
Old June 9th, 2005, 03:57 PM
Abrooks's Avatar
Abrooks
Tony Brooks
If you're that desperate, I'll have a go at welding it for you. Oh, and it's not stainless. Or at least the factory y isn't.
Old June 9th, 2005, 04:08 PM
Hehe. I dont call it desperate, but if it works for you
Yeah it doesn't look stainless to me.
I also need to cut off the aftermarket muffler thats been welded on it and weld on a flange so I can mount a stock muffler. I have everything except the hangers.
Still game? Lemmie know when you have time and where you want to do this
charles
Old June 9th, 2005, 05:11 PM
Abrooks's Avatar
Abrooks
Tony Brooks
For the muffler, just get the flowmaster and clamps, though I could most likely burn that together for you too.
Sure, I'm game, only problem is that it'll have to wait until July as I'm getting hitched next weekend and won't be back from the honeymoon until the end of the month.
Let me know!
Old June 9th, 2005, 05:12 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
I recently "cracked" my tailpipe. Nothing a little sawzall didn't fix.
Now to the pipe bender in the shop.
"It's not a Jeep"
Old June 9th, 2005, 05:41 PM
Hey Tony, no problem on the wedding there - you know my policy - your excused if it's your wedding I had forgotten you told me about that. Congrats in advance and have a great honeymoon if I don't talk to you before then.
If I can't scare up any help sooner, I'll definatley take you up on the offer!
Regarding the flowmaster, I already have a (used) stock muffler and tailpaipe, and a flange to weld on, so I'm all set there. A quiet muffler will be a welcome change for my current redneckish setup.
charles
ac, rack
Custom exhust setup? Pipe size to use?? Defender50th Defender Technical Discussions 8 November 22nd, 2005 12:21 PM
Tail pipe replacement d90Monkey Defender Technical Discussions 9 March 24th, 2005 12:10 PM
Exhaust Pipe Removal Question Rob Defender Technical Discussions 0 September 17th, 2004 02:27 PM
Tail Pipe Burke Defender Technical Discussions 4 February 7th, 2004 01:53 AM
