Cracked Exhaust Manifold - Defender Source
Old June 12th, 2004, 05:11 PM
jamieh64
Jamie Hanifin
1998 Disco
Red face Cracked Exhaust Manifold
The manifold on the passenger side is cracked pretty bad and needs to be replaced, my question is does the passenger side mean "left side" or "right side" when I go to order a new one?
muchas gracias
jamie
Old June 12th, 2004, 05:22 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Should be right side. If you are ordrering it from any company in the USA it should be fine. If you are ordering it from the UK specify right or left hand drive.
Old June 12th, 2004, 05:27 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
muchas gracias
jamie
Rovers North has it listed as a right side manifold for $181.75. You could also have the manifold coated by the likes of Jet Hot or another comapany prior to installation for long term good looks and some heat containment.
EwS
Old November 20th, 2005, 01:35 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Just noticed a hairline crack on the pass side, top center above the joint with the y pipe. It makes a tiny click sound when engine cold, and looks like it's been there for quite a while.
Anyone hazard a guess how long these things will go before total failure?
Doug W.
Old November 20th, 2005, 07:07 PM
Jimbo's Avatar
Jimbo
James Falchetto
Doug W.
Running in rocks in the craggy mountains around here, the manifold tends to go from crack to breach after a couple of weeks. One solution: arc/stick weld since it's cast iron.
Other more expensive - tubular exhaust manifold, as long as it's legal in your state. Drawback: the whole exhaust has to be changed to make it worthwhile.
Sincerely
Jim
Old November 20th, 2005, 07:48 PM
why buy new? the LR Manual for Africa "Working in the Wild" says "drill a succession of holes along the fissure, pack with prairie grass, and insert an appropriately sized self-tapping screw into each hole.
Old November 20th, 2005, 11:31 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Why don't I own this manual?
"It's not a Jeep"
Old November 22nd, 2005, 03:28 AM
cdmbrennan
Chris Brennan
Prairie grass aside, the company that manufacturers POR-15 has a kit for repairs to an exhaust manifold for something like $35. You basically have to remove the manifold, sandblast it, fill the hole with the high temp cold weld stuff (similar to JBWeld) and then coat with high temp rustproofer. I've done this on one manifold and have had no issues whatsoever- would recommend it. I imagine that Eastwood has a similar kit- heck, even JBWeld might have a high temp weld. Just a suggestion...
cb
Old November 22nd, 2005, 09:01 AM
Grind it clean with a Dremel, drill a stop hole at the end of the crack and JB weld it up! My look "ghetto" but it should work well.
JB Weld Web Site
Tuners using JB Weld on exhaust thread
Old November 22nd, 2005, 01:04 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
I think I have a used passenger side one that is still good. I could look it over and make sure there are no cracks and you can buy it off me if you want to go that route. email me at bradleeduncan AT gmail DOT com
ac, exhaust, rack
exhaust manifold temp? MUDSUX Defender Technical Discussions 4 November 19th, 2009 08:43 AM
300Tdi exhaust manifold problems crown14 Defender Technical Discussions 12 July 8th, 2009 11:38 AM
Place your bets, Blown head gasket, or cracked manifold? Hans Defender Technical Discussions 12 March 20th, 2008 08:02 PM
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
» Defender Registry
Roi
Bassi
Blue Mule
don
Add your Defender
