cracked brake booster: interchange? - Defender Source
Old November 23rd, 2007, 10:11 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
First of all, I'm at a loss as to how my brake booster could have cracked, but it is (near where the master cylindar mounts). So, I've either got to take it off and weld it, or find a replacement.
Is this the same booster as that on a similar vintage Discovery or Range Rover? If so I might be able to find one fairly easily/cheap. Otherwise I think I'll weld it..
Thanks..
Old November 23rd, 2007, 11:02 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Defender Boosters are not the same as Disco1 or RRC (that I've seen). Vacuum Boosters on D's are single diaphram whereas D1's and non abs RRC's are dual diaphram. The space required under the hood made this a requisite (duals = smaller diameter)
Keith
Big, Red and ... aaa Red..
Old November 23rd, 2007, 11:13 PM
You need one off a D-90.
Old November 24th, 2007, 10:24 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Thanks for the info guys. Looks like it's time to break out the welder.
Old November 29th, 2007, 08:33 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
FYI, I tried welding the thing, and it's really thin metal & there were several stress fractures around where the master cylinder mounts. In the end the welding didn't fix anything, so I smothered the cracks in JB Weld (which is holding for now) and ordered a new one. Dealer item only, so I got one from George at RDS.
I'm still a bit baffled how that could become fractured - I've never seen that before.
ac, boost, brake, rack
brake booster? tomaco1 Defender Technical Discussions 3 October 2nd, 2009 04:15 PM
Quickest way to change a brake booster? Hoosier Defender Technical Discussions 1 May 13th, 2009 08:29 PM
Brake Servo / Booster -- Any Interest For cheap group buy??? Heath For Sale - Parts 6 August 12th, 2006 07:05 AM
