couple of things - Defender Source
Old October 5th, 2005, 02:37 PM
jblieb
john
couple of things
(1) my a/c keeps blowing a fuse and will keep blowing just not cold. Replace fuse=cold air for about 10 minutes then the fuse blows again. Mechanic thinks it is a wiring issue. Thoughts?
(2) My buddies d-90 has a an odometer that flashes at various times. Needs to be replaced?
Old October 5th, 2005, 02:53 PM
Sounds like the wire running the compressor clutch is blowing the fuse. Take a look at the AC compressor there should be a wire running to the front of it, I would give it a good look over to check for nicks, cuts and shorts.
What do you mean it flashes? Does it take off it's clothes?
Old October 5th, 2005, 02:57 PM
m.michaels
Matthew Michaels
1997 D90 SW
Just the Speedo
Try this out:
http://www.defendersource.com/forum/...ead.php?t=3035
Old October 5th, 2005, 04:36 PM
Jase
Jase
pending
I had an odometer that flashed off/on/extended off when the truck was between 29K and 36K. After 36K it stopped flashing and worked correctly.
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Strange things growing in my wife's garden... Trigger Misc. Chit-Chat 9 August 30th, 2005 02:26 AM
Things that make you go hmmmmmm Davis Misc. Chit-Chat 5 August 26th, 2005 12:54 AM
Things to look for in a NAS D-90 rayblake Defender Technical Discussions 10 November 14th, 2003 01:43 PM
