Could use some help with misfire diagnosis - Defender Source
Old January 18th, 2018, 01:23 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
So I am on the road and the truck, 1997 D-90 with a 4.o, is running a bit crappy.
Started acting like a misfire on the highway the other day and I am having trouble nailing it down. Would love some help before I have to head back home on Sunday for the 9 hour drive.
Here is what I have done, checked etc...
Got the codes read when first realized it was running poorly.
Code was a misfire #1 Cylinder. Pulled that plug as the truck burns some oil and suspected a fouled plug. Plug not fouled with oil but didn't look great as it had gunk of sorts packed around the electrode. Decided to change the plug out.
Cleared the coeds and headed down the road. No improvement. Stopped again. Codes this time were P3999 and P1316 . Did some research and could not find 3999 code but found 1316 to be misfire excessive emissions fault. But not cylinder #1 this time. Checked all the plugs after getting to my destination. All look okay but #1 was wet and smelled of fuel. Figured it was not firing. Bought an inline spark tester and verified spark at plug. Then thought perhaps it was fuel related so I disconnected battery in hopes of resetting system etc... Fired it up and it ran like a charm. Engine was cold. Thought I was good to go. Drove it today and back to rough idle like before.
Truck seems to run smooth at highway speeds but not at idle or low speed. Also replaced plugs, wires, and new heads/head gaskets less than two years ago.
Any ideas?
Also, wondering now if it may be bad catalytic converters as mine have been rattling for a while but never got around to fixing it. Could they have gotten worse on the drive causing truck to rough idle when warm? Would that explain the code?
I am a bit lost as to what to do and would love some insight so I can feel comfortable driving it home.
Old January 18th, 2018, 07:34 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
You might be on to something re bad cats. Perhaps they have compromised the O2’s and sending a false signal. Im assuming no you have a CEL?
The Rangie and Disco guys on DWeb may have insights that are helpful as well.
fire, misfire
Misfire / Very poor fuel economy Jerry Defender Technical Discussions 14 November 13th, 2017 10:24 PM
Cyl 5 Misfire Mpower619 Defender Technical Discussions 6 January 7th, 2012 11:10 PM
ignition/engine misfire code (sleuth work needed) hlamar Defender Technical Discussions 7 July 19th, 2010 08:06 AM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
