Corroded Heat Pipe - Defender Source
Old October 19th, 2007, 12:24 AM
bjenk
Brian Jenkinson
1994 D90
Corroded Heat Pipe
It seems that while fixing one thing I notice three other things that need attention. Not complaining because I am able to do most of the wrenching at work...
While replacing the water pump the other day I had to use channel locks to remove my coolant plug that is on the heater supply line. When I got it off all but two threads were left on the plug and the pipe is corroded so bad, that there is no threads left. I had to just spin until it locked up to get it home.
I called George and he had never had to get this part, let a lone know what to call it...
I came up with a simple solution that seems to be working very well and thought I would pass it on. I bought it at Ace Hardware for a couple dollars and have driven about two hundred miles with out a leak. It is just a simple drain plug. I might actually try it in the radiator, because I hate that stupid plastic plug.
brian
Old October 19th, 2007, 08:30 AM
epninety's Avatar
epninety
Dave Haynes
Ibex 240 2.8TGV
Not much help to you if theres no thread left in the pipe (it's not just clogged with plastic right?), but I think the plug is the same as used on the TDi, part number ERR4686.
I replaced both of mine (tdi) with a hydraulic pipe stop, it's a 1/2"BSPP thread, hydraulics people know it as G-1/2. I think theres a US operation of RS Components... part number 727-755 is what I used.
http://www.ep90.com/index.php?id=92
Dave
Old October 19th, 2007, 09:33 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
brian
It looks like a Wine Bottle Stopper... What is it made of, is it likely to hold up to the temperatures over time?
~Scott T.
'95 D-90 ST - AA Yellow
Old October 19th, 2007, 10:44 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
It looks like a drain plug for a boat to me. My guess is that it is made of rubber.
Old October 19th, 2007, 10:48 AM
bjenk
Brian Jenkinson
1994 D90
It seems to be brass hardware and a rubber stop. I will post if I have any issues in the future. It is just a cheap alternative for me.
brian
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Custom exhust setup? Pipe size to use?? Defender50th Defender Technical Discussions 8 November 22nd, 2005 12:21 PM
Heat insulation blankets kellymoe For Sale - Parts 1 July 13th, 2005 04:54 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
