correct thermostat for 1988 3.5 - Defender Source
Old February 18th, 2014, 11:07 AM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
I looked through the threads and my references but cannot find the recommended thermostat temperature for my 1988 D110 with the 3.5 carburetted engine. Is it 180 degrees or 195 degrees? something else.
Also it looks like the thermostat housing is at the front of the intake manifold where the upper radiator hose attaches. Can someone confirm?
thanks.
Surprisingly the 90/110 shop manual I have is missing most information on the 3.5 engine. I need to find a better manual.
'88 ROW 110 5-door SOLD
'01 Disco II
'95 RRC LWB
Old February 19th, 2014, 08:24 AM
LRover's Avatar
LRover
J. Michael McCaig
For a carb equipped Rover V8 you can use 180F thermostat year round or install a 195F for the winter and a 160F in the summer. Fuel injected run the 195F year round. Rovers North part # for the 180 is PLH386 or you can go to the local auto parts store and buy one for a 1962 Buick Special 215 if they still have a listing. You will have to make a gasket as the housings are a little different. Yes, the thermostat is where the top radiator connects to the intake.
Old February 21st, 2014, 05:39 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
195F is too hot. The manual says the thermostat is ok if it's open between 85c (185F) and 89c (192F).
A 195F only starts to open at 195 and isn't fully open until over 200. At least all the domestic ones I've tested are like that.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 21st, 2014, 07:35 AM
LRover's Avatar
LRover
J. Michael McCaig
Agreed. I changed the thermostat in my '95 RRC to 180f. Might be running a little rich because of it, I don't know, but I rather have that then being close to overheating from the begining before it ever works hard.
Old February 22nd, 2014, 08:11 PM
akrockhound
Jack
1988 RHD 110
thanks
Rovers North sells the 88C/190F thermostat (RNC047) for the 3.5, 3.9 and 4.0 but my shop manual shows a 82C/180F thermostat for the 3.5.
I believe the fuel injected engines are set up to run a few degrees hotter than the carb ones. My Disco II runs pretty steady at 193F and can go up to 203F when I lug or city drive so I suppose its a 195D thermostat.
'01 Disco II
'95 RRC LWB
Old February 22nd, 2014, 08:26 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Curiously enough the efi 3.5 in my 1980 SD1 used a 82 degree thermostat.
Old February 24th, 2014, 08:23 AM
LRover's Avatar
LRover
J. Michael McCaig
The higher temp t'stat in the later FFI engines was to reduce emissions.
thermostat
Side step install - do it look correct? paulb Defender Technical Discussions 10 January 25th, 2008 02:53 PM
Throttle Body Injector (TBI) for 3.5 V8 gregorw47 Defender Technical Discussions 9 January 8th, 2006 12:55 PM
How and Why to add an oil thermostat Hans Misc. Chit-Chat 0 February 18th, 2005 03:57 PM
Thermostat question~ obie Defender Technical Discussions 3 October 21st, 2004 12:44 PM
Odometer/speedo correct? sherpamike Defender Technical Discussions 2 October 15th, 2003 08:52 AM
