Correct part #'s for NAS rad hoses - Defender Source
Old November 9th, 2013, 06:03 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Need to order a pair of rad hosed for my D100 project, engine is an ex-classic RaRo 3.9 so looks the same as the attached pic. I'm fairly confident the top hose is a NTC5686 but am not sure on the lower, after searching all I find listed is the PCH116030, but that has 2 engine side hoses so I suspect it's for the later serp engine.
The other alternative I've found is the RaRo hose NTC5632, this has the right number of ends and looks like it'll fit ok.
Will be in the UK until Weds, so need to sort ASAP to get them from the local LR main dealer.
Many Thanks......
Name:	NAS Engine.jpg
Old November 9th, 2013, 06:18 AM
Interesting
If you are using a Defender type radiator I'd check the early 3.5 defender part numbers. Likewise if a rec/d1 type radiator 3.5 hose for that.
Old November 9th, 2013, 06:26 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by Rocky View Post
Interesting
The rad is( will be as soon as it arrives ) an Allisport V8 one, with straight inlet/outlet pipes, and engine is a 3.9efi so looks sames as the pic. Long term I have a 3.9 D2 short engine I'll rebuild with 4.6 internals & then swap in using the non-serp front timing cover etc. as it's already setup for Ford EDIS coil packs & Megasquirt. Should be a good puller then
Old November 10th, 2013, 07:42 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Bumpty..... off to the LR dealer in the morning.... going for these then ?
nas, part
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
radiator hoses jperakis Defender Technical Discussions 1 March 28th, 2005 08:12 AM
Part number for 300tdi D90 steering wheel? dmarchand Misc. Chit-Chat 12 June 22nd, 2004 10:28 AM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
part #'s for clips mattdh Defender Technical Discussions 5 October 10th, 2003 10:13 AM
