correct engine temp - Defender Source
Old May 18th, 2008, 04:15 PM
stephen
stephen beacham
97 defender 90
correct engine temp
i have a 97 d-90 with a 4.6. It seems to run ok, i was just curious what the proper engine temp range should be under normal driving conditions. mine seems to be around 210 degrees. also what level should the expansion tank be at when engine is cold? thanks for the help
Old May 19th, 2008, 01:05 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi stephen,
the best answer is a couple of degrees above the opening temp of the thermostat, this can range from 77 to 88deg C on standard V8's so a running temp of 90deg with an 88 deg thermostat is common.
the rating of the 'stat will be stamped on it.
The level should be marked on the expansion bottle depending on the type, again however half full is always a safe bet.
regards
Gren
Old May 19th, 2008, 02:09 PM
btate
Bryan Tate
d90
I got 190F at the vdo dash gauge and measured 200F with the "laser gauge" aimed at the temp sensor housing.
Old May 19th, 2008, 03:36 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I run about 190F. I have a 4-core radiator, Thermoflex fans. I rarely get to 200, but if I am traveling up hills in the mountains, I can. Nothing to really worry about until 210-220, IMO.
Old October 3rd, 2008, 08:21 PM
any other thoughts on this. I seem to get around the 190 mark in town but on the interstate I was 200-210 range running 70-75? I think those Hellas in front of the radiator might be part of the problem. TBD.
Old October 6th, 2008, 09:34 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
VDO temp guage 180 to 195 with stock radiator in summer and 180 -185 in winter
engine
Correct intercooler for International 2.8 engine Santiago Defender Technical Discussions 5 June 13th, 2008 04:12 PM
Engine Temp issues sflash868 Defender Technical Discussions 11 May 25th, 2005 04:51 PM
Engine Temp - Normal range mgrgpg Defender Technical Discussions 5 June 10th, 2004 08:47 PM
