Corect V belt tension 3.9 - Defender Source
Old October 15th, 2012, 09:01 PM
wantone
Rick Thompson
94 ST #1222
Hi guys, what is the correct belt tension for the alternator, water & power steering pump belts?
I have changed belts on other cars before but not on the D-90 & know how "delicate" they can be sometimes.....
Thanks!
Old October 16th, 2012, 09:33 AM
Naplm00
Matthew
i put all vbelts on all my cars to 1/2 in deflection when pushing on the longest unsupported area of the belt
not an exact science , but it hasn't failed me
Old October 16th, 2012, 09:42 AM
wantone
Rick Thompson
94 ST #1222
thanks matt, thats what i typically do on belts as well, just wanted double check that rover did not have some funky specs
Old October 16th, 2012, 09:57 AM
x2 this is what I did exactly when I replaced the A/C belt on the 110, and recently when I replaced the alternator on the 90...about 1/2" deflection and likewise this worked for me on both trucks.
Old February 2nd, 2013, 08:21 PM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
How in the world did you guys loosen the belt for the water pump / crank?? I can not for the life of me get to that idler pulley loosening nut. Is there a trick or another place I can loosen that belt??
Edit: my loosening nut is sitting right on the crank shaft pulley. I can't get an angle on it
Old February 2nd, 2013, 09:42 PM
Steering pump takes 2 people.
Old February 4th, 2013, 08:28 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
It's probably MUCH easier with 2, but you can do it with one person.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old February 4th, 2013, 08:31 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
True. I did it the other night. Loosen it all up and use the alternator to get it as tight as possible then tighten the power stewing pump down. Then adjust the alt belt
Old February 4th, 2013, 08:50 PM
Surf90's Avatar
Surf90
C.S.
I'm officially on day 3 of trying to get the idler pulley pinch-bolt loose for the crank belt. I've tried every tool at every angle and to no avail. I don't know what to do. I may have to drill it out from the opposite side?? I mean it is just sitting so tight on the alt pulley that I cannot get anything on it. I'm so frustrated.
Old February 4th, 2013, 09:23 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Take the fan off cut the belts use a box end wrench on the nut if not apply some heat with a small butane torch to the treaded side or you and try tapping the bracket to rotate it so you can access the bolt easier...... no matter how many i do that's the one job i still hate
No Mall crawler here
Old February 4th, 2013, 11:23 PM
MonLand
Loic Fabro
X2 on removing shroud and fan. Replaced my water pump (and all belts and hoses) just a few weeks ago and the fan/shroud out opened a ton a room. I think I untied mine with a regular flat wrench. It should not be that tight. Are you sure you're turning anti-clockwise (sorry... Nothing personal... I so that myself all the time! ). I did this without a shop manual, so this is not rocket science (once you've done it once).
If your bolts are frozen, soak them in wd-40/liquid wrench/etc twice a day for 2-3 days in a row. Heat should really not be necessary (well... I should not have had to cut the bolt holding the starter neither... ).
MonLand
1995 D90 NAS
1996 Discovery NAS
Belt removal on a 97 thelandroverguy Defender Technical Discussions 10 July 31st, 2011 09:41 PM
any 95, 3.9 water pump tension pulleys out there? snosrfr Wanted 8 October 28th, 2010 11:20 PM
belt tension on a 95? durangorover Defender Technical Discussions 2 June 3rd, 2009 11:37 AM
For Sale: 3.9 Complete Joe B For Sale - Parts 1 April 20th, 2004 03:54 PM
