cooper st tyre pressure - Defender Source
Old September 10th, 2010, 05:50 PM
defender900
jerry parker
1991 defender 90
just got a set of 235/85/16 cooper st's for my D 90 ,what pressures should be in them ?
Old September 11th, 2010, 07:03 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
If you call Cooper and give them the running axle load they'll give you the suggested pressure.
For instance, I called Cooper and these were the inflation pressures for my old style load range D 7.50Rx16 Discoverer STT's
Loading
per
wheel
in
pounds PSI
2390 60
2190 55
2040 50
1930 45
1770 40
1620 35
Or you could just cover an area of the tread with chalk or paint and roll your vehicle forward and adjust as needed so you have an even pattern the full width of the tread.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 11th, 2010, 08:42 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Maybe we should add a new section to the forum so people can ask what pressure to run over and over and over and over and over and over and over and over and over and over and over and over and over and over?
Old September 11th, 2010, 04:54 PM
defender900
jerry parker
1991 defender 90
maybe you should stop being so sarcastic and give sound practical advise,you never know RICHARD CRANIUM you might need some help one day
Old September 11th, 2010, 05:20 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Lighten up Jerry and consider using the SEARCH function.
BF Goodrich Tyre Pressure Recommendations Manimal Defender Technical Discussions 5 November 5th, 2008 11:43 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
Tire question (yet another one) Cooper JackW Defender Technical Discussions 0 October 20th, 2005 07:39 PM
OEM tyre pressure on NAS D90s DiscoDino Defender Technical Discussions 3 May 21st, 2005 04:49 PM
