Cooling system leak - 3psi in 2 hrs? - Page 2 - Defender Source
Old May 8th, 2013, 11:33 AM
sro
Sam Odio
2008 LR2
Originally Posted by Jymmiejamz View Post
Radiator or fan clutch would be my guess.
I have noticed the fan is running even when the system is cool. According to my manual it should only engage when the air around the radiator reaches a certain temp. Also, I've tried the newspaper test and have never been able to stop the fan (even when the engine is cold).
What's the best way to test for a blocked radiator or failing waster pump?
Old May 8th, 2013, 11:53 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
I can most assuredly say that your radiator is the issue. It may need to be replaced, recored, or just cleaned and flushed. Buy an IR thermometer and start there. They are cheap.
Just to be sure, you still have the fan shroud installed, right? And the front grille isnt completely blocked with junk like leaves/mud/etc?
Old May 8th, 2013, 07:04 PM
fan clutch wouldn't cause system to failure to pressurize
How is he determining the pressure? By feeling the hoses? That's not very scientific.
Old May 8th, 2013, 10:22 PM
Agreed but i can clearly determine the difference between my flaccid member and my raging stiffy by touch .. So judging that the cooling system has pressurized isn't too much of a stretch.
Old May 22nd, 2013, 11:53 AM
sro
Sam Odio
2008 LR2
I was able the get the system to pressurize after a long highway drive. It doesn't pressurize when I drive shorter distances (even though it gets up to temperature), but I now think that's normal.
That said, I just recored the radiator. It was about 30% plugged. We'll see if that addresses the overheating issue.
Old May 22nd, 2013, 02:17 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Hope it is all solved! 30% is significant for these trucks...
Old June 12th, 2013, 12:28 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
sro - did you solve the overheat problem? I just replaced all components of my cooling system and am experiencing similar issues to yours. New radiator, hoses, sensors, thermostat and cap. Water pump only has a few thousand miles on it. The engine runs hot and the top hose remains cool and with no pressure. Not sure if I have an air lock after filling the coolant or if there is a bigger issue.
Would like to hear how it turned out for you.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old June 12th, 2013, 01:02 PM
transientmechanic
1972 SIII
Sounds like you have an air lock, here is the magic bullet:
http://www.amazon.com/UView-550000-A...ystem+refiller
Old July 2nd, 2013, 03:42 AM
sro
Sam Odio
2008 LR2
Radiator blockage was the issue for me. New larger rad solved all issues.
Old July 2nd, 2013, 08:40 AM
That is probably the most useful/time saving tool I have ever purchased.
Pressurized cooling system....when cold? RyanB16 Defender Technical Discussions 9 December 29th, 2008 12:26 PM
HS 2.8L TGV Cooling System Inline "Valve" DesertRat Defender Technical Discussions 3 November 3rd, 2008 12:12 AM
Flushing cooling system CGunther Defender Technical Discussions 0 July 31st, 2006 11:51 PM
Cooling system pressure Antonios Defender Technical Discussions 15 November 1st, 2005 01:33 PM
cooling system rover4x4 Defender Technical Discussions 1 October 21st, 2004 02:02 PM
