Cooling Issues / radiator hole - Defender Source
Old August 27th, 2010, 12:56 PM
MUDROVERNC
Michael Wilfong
1994 Land Rover Defender 90
Hey guys,
Okay...the never ending heating issues. First I will tell you what I have done then I need your help.
Engine was overheating once the car had stopped (redlight or traffic) and would not return.
What I have done so far:
New thermostat. with Fail open Auto Zone $13
Radiator Flush: $99
Still overheated and determined Fan Clutch. Bought Fan clutch for 119 at auto zone. and went ahead and bought water pump $239.
Fan clutch is reverse thread. 32 mm wrench needed. I actually used an adjustible. and a rubber strap to hold the pulley from moving. You have to remove most belts to get to everything from the water pump.
NOW everything is back in place no leaks yet on the water pump however. I hit the radiator with my wrench and busted a tiny spot where now coolant leaks. Also what is the best way to get coolant back in the radiator?
HOW CAN I FIX THIS??? please help
Michael Wilfong
Michael Ryan Realty
704-621-0922
Old August 27th, 2010, 02:17 PM
Temp fix is Rad weld or similar from autozone type place ... or an egg white ( bush mechanic fix ) not recommended but might get you out of deepest jungle.
Permanent solution is recore the rad - search radiator repair in your local yellow pages or similar.
It may be possible for them to patch the hole but a recore would help with the cooling.
Old August 27th, 2010, 07:44 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Take it to a shop, they'll have to unsolder everything, knock a few fins out, copper solder it up, heat dip and test it.
Robert Deniro
coolant, fan clutch, overheating, radiator, water pump
Cooling issues slorocco Defender Technical Discussions 10 December 13th, 2010 01:08 PM
Radiator Cooling Trouble mgrgpg Defender Technical Discussions 29 March 14th, 2005 05:43 PM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
cooling system rover4x4 Defender Technical Discussions 1 October 21st, 2004 02:02 PM
EMERGENCY-Xfer case issues Cyborg Defender Technical Discussions 7 July 18th, 2004 02:50 AM
