cooling fan not elec. - Defender Source
Old September 18th, 2009, 12:18 PM
Has anyone tried an aftermarket fan. Ive searched a lot of thread but havent found anything.
Old September 18th, 2009, 02:05 PM
Doesn't Flex-i-lite have a fan that works with a fan clutch?
Old September 18th, 2009, 02:22 PM
Phillip I snagged this off the www once.
"if you have a '95 Classic or Defender with the serpentine belt, you are lucky. Go to Autozone and ask for the fan clutch for a 1998 Chevy Blazer, engine 4.3l V6 with a/c. Part number is : Regular duty 922744 : $ 59.99 Extreme duty 922786 (old #215158) : $66.99 -- this is the one recommended for LR use."
So my guess is if you got the fan that went with one of these fan clutches it would work (Assuming the size is close)
hth
charles
Old September 18th, 2009, 02:24 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
I bought one from autozone a few months ago and haven't had any problems since.
Old September 18th, 2009, 05:46 PM
not the clutch the fan.
hth
charles
v belt trucks have a different thread on the water pump/.
Old September 18th, 2009, 06:24 PM
yeah mine is serpentine. I was just saying that if compatible clutches are available, those clutches must have fans right? Try find the fans that go with those clutches - they are the same size as the D90 clutches
Old September 18th, 2009, 07:57 PM
I am just trying to move more air, those torqflo clutches from auto zone arent worth a shit.
Old September 18th, 2009, 10:49 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
you can use a serp belt fan, just reverse it
Old September 18th, 2009, 11:15 PM
I dont know that it would move anymore air than whats stock already.
I wish there was a v belt alternative to that Chevy fan clutch. I run below 180 when I am on the highway, but when I am in town and the woods I can easily get to 200. I have had the radiator serviced and flushed the system. I dont think removing the AC condenser will help. I am not sure what people are running in the woods but I know upwards of 200 is a consideration for these shitty ass engines.
Old September 18th, 2009, 11:48 PM
Pendy taught me a trick which lowered my temps by a few degrees - get some pipe insulation and use it to fill the gaps on the sides and bottom of the radiator. It forces the air to go through the radiator and not around it. Make sure your shroud fits well too.
Old August 15th, 2011, 08:01 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Reviving this one...I tried to the Chevy fan clutch from Autozone (with the part numbers above) but the bolt holes do not even come close to working with my fan. The bolt circle on the fan clutch appears to be a solid 1-2" too small. Anyone else run into this?
guess I'm back to ordering one from the usual suspects and waiting...
Old August 15th, 2011, 08:11 PM
That is for a serpentine configuration. Try a rrc fan and clutch, there is a thread on this.
fan
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
Radiator Cooling Fan mdmccallum Defender Technical Discussions 10 January 16th, 2009 10:02 AM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
looking for a viscous cooling fan drork Wanted 1 July 1st, 2004 11:29 PM
