coolant temp sensor - Defender Source
Old August 9th, 2008, 09:48 AM
coolant temp sensor
The single wire sensor in the intake. Does it need teflon tape or pipe "dope". Does the sensor ground to the intake since it has only one wire? The sensor is brass and I dont use anything on brass fittings. How much coolant can I expect to loose when I remove it.
Old August 9th, 2008, 10:30 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Use a little dope at the back end of the threads to avoid leakage but still let it ground. Just have the new one ready to go when you screw the old one out, just a small mess.
coolant, sensor
300Tdi locating coolant temp sensor? crown14 Defender Technical Discussions 10 February 22nd, 2017 05:10 PM
Fuel Temp Sensor engine code Tim Scully Defender Technical Discussions 0 January 9th, 2008 08:34 PM
Erratic Oil and Temp Sensor Jon_Winningham Defender Technical Discussions 10 March 30th, 2007 09:27 PM
fuel temp sensor mattdh Defender Technical Discussions 2 May 13th, 2006 08:59 PM
