Coolant Tank ? NAS 90 - Defender Source
Old July 25th, 2013, 03:41 PM
bjp
Brent
1995 D90
Are there any issues with the function of the Expansion Tank if I lower it 3 or 4 inches to avoid the rubbing of a new Puma Bonnet.
Old July 25th, 2013, 09:01 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I was always under the impression that the level of the tank was important--that it was set to the level that when properly full would be at the level of the coolant at the highest point in the system. That said, I hate the small, metal tank that came with the D90 (and RRC) and changed it out to the Disco1 style (with slight coolant line change adding a T-in at the heater line) and I mounted it so that the fluid when properly full was at the same level. My guess is that by lowering it, you may have more coolant in the resevoir which more likely than not would blow out when getting hot leaving you with too little in reserve. I am guessing--I would love to know what others have to say.
Old July 25th, 2013, 10:55 PM
Sounds right to me.
Old July 26th, 2013, 08:42 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Might have problems bleeding the system too.
Mike Hammond
Old July 26th, 2013, 02:00 PM
CDeWan
Clay DeWan
5.3L beastie
sh*t barry didn't think about that for the puma bonnet conversion
90, coolant, nas
Galvanized NAS Tank Guard Oliver Whiting For Sale - Parts 2 March 31st, 2011 09:58 AM
FS used NAS 90 frame ECR The Vendors Loft 2 March 28th, 2011 08:42 AM
Safety Devices 110 Wagon and NAS 90 Wagon cages in stock ECR The Vendors Loft 2 March 3rd, 2011 04:22 PM
Modifying an Equippe fuel tank guard for a NAS 90 Gene B Defender Technical Discussions 10 February 13th, 2009 05:25 PM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
