Coolant system pressure "vs" gagging at high rotation - Defender Source
Old April 8th, 2014, 09:10 AM
fmrodrigues
Frederico
2000 Defender 90 SW
Hello,
Some time ago, when I was driving my 2000 110 TD5 SW, with 180.000 KM, for a few instants it suddenly lost power.
It happened a second time and this time I was able to see the temperature gauge going, momentarily, to the red.
When I stopped I found out there was, more or less, 1 liter missing from the coolant expansion.
(I donít know if this quantity was enough to justify the overheating)
After refilling, everything seemed normal but when I stopped there was water leaking from the back of the head - Plug Core 37D2260L.
(2 photos)
After replacing and checking the coolant level, I went for a short ride.
At high rotation there was some gagging.
After stopping I took the coolant expansion cap off.
(2 videos)
http://youtu.be/-whZRWGWpTk
http://youtu.be/VGHyy9ggiP4
There was a lot pressure inside and the water rose to the opening level.
I donít know which should be the correct pressure value inside the coolant system, but I tested it for exhaust gas and the result was negative.
(1 video)
http://youtu.be/IX3o4CHwV2s
Iím not convinced everything is OK, the gagging at high rotation is still there and the coolant system is always with a lot of pressure in.
Can someone help?
Thanks in advanced.
Frederico
Name:	110 water leak.JPG
ID:	92629   Click image for larger version
Name:	110 water leak 2.JPG
Old April 8th, 2014, 10:51 AM
have it filled under vacuum ... thats the proper way to ensure no air cavities in the system,
Old May 20th, 2014, 06:43 AM
fmrodrigues
Frederico
2000 Defender 90 SW
Here goes a photo from the water pump.
The blades were completely rusted away.
I just hope the overheating didnít damage the head gasket!
I will keep you informed.
Frederico
Name:	110 Water Pump.JPG
Old May 20th, 2014, 08:12 AM
Makes me want to question the quality of the antifreeze in the engine.
Good time to check the radiator to. Flush up out to remove debris
Old May 20th, 2014, 08:26 AM
The system should be at about 1 bar under normal driving. This pressure allows the coolant to go over 100 C without boiling. More than that and you probably have a bad head gasket.
------ Follow up post added May 20th, 2014 08:26 AM ------
Frederico
Must be Britpart
Old May 21st, 2014, 10:30 AM
fmrodrigues
Frederico
2000 Defender 90 SW
Have no idea about the brand, but looking to the elbow I agree with Rocky, the antifreeze wasnít any good!
Frederico
Name:	110 Elbow.JPG
coolant
300 tdi injectors - high pressure injector option for replacement? nathanwind Defender Technical Discussions 14 July 7th, 2017 03:00 PM
300TDi PSC reverse rotation PS pump Buckon37s For Sale - Parts 1 August 9th, 2013 12:00 PM
Introducing the spare into the rotation down_shift Defender Technical Discussions 2 November 24th, 2011 11:10 AM
Source for hard line (High pressure bypass?) on steering box? KevinNY Defender Technical Discussions 17 October 29th, 2009 11:33 PM
NAS 110 A/C High Pressure Valve Mikenbama Wanted 6 September 1st, 2009 02:30 AM
