Coolant System - Defender Source
Old February 25th, 2015, 08:10 AM
Defender_90
Kevin Doonan
1999 RR HSE
Coolant System
Hi All,
So my truck is an everyday driver in Stamford, CT. Just recently I noticed that I was losing a anitfreeze and figured that this might be normal d-90 behavior....
So, I topped of the reservoir and have been checking under the truck frequently. Last night and this morning the fluids have been coming out at an alarming rate from under the truck. (worse when I turn the heat off)
I cannot pin point the leak, but from what I can tell its not from the any of the hoses, but rather from the back of the motor, just about where it hooks up with the transmission closest to the heat exchange. To be most specific, it appears to be just above the headers and the the left ( if that makes sense)
Now granted without pictures it would be hard to know exactly what the issue is, but looking for thoughts and opinions on what it might be and the best way to have the system tested/how expensive.
Thanks in advance...hopefully a realtively easy fix otherwise have a 94 4 sale......no more money pit for me.
Kevin
Old February 25th, 2015, 08:32 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
With limited info, I'd guess it is your water journal at your head gasket leaking. Need to change your head gasket. But, it could also be draining down from your valley pan which could be a simple leak from your plenum cooler lines or thermostat that runs down the back during uphill or acceleration. First, take a look under your plenum and see if top of gasket is wet. I usually park on an uphill and look at the very back from the drivers side-- you can just see the back of the gasket below the plenum. If you can't see anything then add some dye to your coolant and use a black light too see where the leak starts-- probably at front or rear corners of head gasket. Good luck.
Old February 26th, 2015, 01:47 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
The fix will likely cost you 20k. I'll give you $500 for the truck.
Old February 26th, 2015, 03:07 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Hahahahahaha, I will give you 750!
Attributed to Shayne...
Old February 26th, 2015, 03:47 PM
my guess is the 2 front mini hoses near the thermostat ... one of them has pierced by rubbing on the hose clamp of the other ....
The best way to check for hose leaks is to use a cooling system pressure tester which can be borrowed from your local autozone. Hook it up ... pressurize the system ... look for leaks.
Old February 26th, 2015, 07:35 PM
Delete the throttle body hoses and replace the remaining coolant hoses. Tighten the intake bolts and hope for the best..
coolant
Coolant system pressure "vs" gagging at high rotation fmrodrigues Defender Technical Discussions 5 May 21st, 2014 10:30 AM
Is the AC compressor on a 1994 style system the same as a 95 style system? evilfij Defender Technical Discussions 0 May 31st, 2010 06:20 PM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Tire, coolant and other new owner questions DaveHuny Defender Technical Discussions 2 October 24th, 2004 03:27 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
